simple performance boost - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-04-2005, 02:02 AM   #1 (permalink)
View asus's Photo Gallery
Question simple performance boost
Will changing the spark plugs from stock old spark plugs to new higher performance sparkplugs help?? How about getting rid of the air box and putting an air intake filer on ?? i see them all over ebay??
Is there any inexpensive way to boost performance?? Something that don’t take a master mechanic to figure out..
asus is offline   Reply With Quote
Old 10-04-2005, 08:42 AM   #2 (permalink)
Noog
View crockdaddy420's Photo Gallery
Get a cold intake with a kn filter attached, should be able to install yourself, if you have worked on your car before. That will give you probally around 12hp.
Crizzle Dizzle for Shizzle Bizzle!
Go SOX!!! Yankees you'll soon find out who yo Daddy is Biatch. The yankees bunch a tight wads, don't know how to have fun.
crockdaddy420 is offline   Reply With Quote
Old 10-04-2005, 10:30 AM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Nope not really, power costs money... and no plugs dont give you power, only duty for the plug is to set the air-fuel mixture on fire, doesnt take much to do that, by the time the fuel ignites, the spark is long gone already.
12hp from an airfilter....
Old 10-04-2005, 11:39 AM   #4 (permalink)
Foul Weather Drifter
View SpeedballTrix's Photo Gallery
"That will give you probally around 12hp."
Does this air filter you speak of come with a compressor?
SpeedballTrix is offline   Reply With Quote
Old 10-04-2005, 12:43 PM   #5 (permalink)
Noog
I said above, cold intake. Said he should do up the whole intake. I don't know somewhere around that hp.
Old 10-04-2005, 12:46 PM   #6 (permalink)
Resident asshole
Flashmn's Avatar
Cold or hot either one wont give you 12hp, thats marketing for the ignorant.
Old 10-04-2005, 01:50 PM   #7 (permalink)
Regardless of which Corolla he has, he's not getting 12hp from a CAI.
Old 10-04-2005, 03:41 PM   #8 (permalink)
View tashirosgt's Photo Gallery
Now that we have dismissed cold air intakes, what about crankscrapers? Or doesn't that count as simple? I'm more curious about the effect on MPG in highway driving than more HP.
The people at Ishihara-Johnson pointed out to me that the "windage tray" for the 4age engine only costs about $12 and it fits into the 4afe. But it isn't shaped exactly like a crank scraper so it may have a different function. You can add both the windage tray and a crankscraper to the 4afe, but you won't have any room for gaskets and you will need longer bolts for the oil pan.
tashirosgt is offline   Reply With Quote
Old 10-04-2005, 04:16 PM   #9 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
12hp.. 3-5hp is more realistic.
Old 10-04-2005, 08:21 PM   #10 (permalink)
well.. is it even worth the trouble?? if it will kill my MPG .. forget it lol.. gas already puts a big enough dent in my bank
Old 10-04-2005, 09:40 PM   #11 (permalink)
I love Turbos
View Nismo Convert's Photo Gallery
If you create less restriction in your intake, like your exhaust you will actually gain HP, along with more power, it just works more effeiently, and something like 2 HP is more reasonable, unless your car is boosted.
1986 Mazda Rx7, was base n/a model, now a 290rwhp, pos monster
1991 Corolla LS, 5spd. Sold
1995 Toyota Tacoma, 3" Lift, Bilstein HD's up front 5051's out back, 265 75 15 Toyo OC A/T's.
2009 Toyota Corolla "S" Magnetic Grey, and oh sooooo Stock.`
Nismo Convert is offline   Reply With Quote
Old 10-05-2005, 05:44 PM   #12 (permalink)
View Chinasgotrice's Photo Gallery
Also....dont get any kind of high performance spark plugs that run hotter then your stock ones....it would give more performance cause its hotter to sure burn all the fuel in the chamber. but running hotter puts a hole in your piston.
and a question on air filters? People say that getting K&n one or a cold air intake lets in more dirt? even though k&n claims to help trap more dirt....Im scared to buy one and does anyone know if this is true
Chinasgotrice is offline   Reply With Quote
Old 10-05-2005, 06:50 PM   #13 (permalink)
I love Turbos
Running a hotter plug won't burn a hole in your piston, running it lean on a hotter plug with advanced timming, and low octane fuel will burn a hole in the piston.
The oil on the Gauge Filters (K&N) helps trap the dirt, the paper filters are basically, like putting a paper bag over your intake, it can't breath and decreases the effiecency, a little bit of dirt isn't going to hurt a motor.
Also, hotter plugs within reason 1-2 heat ranges will also increase fuel milage.
Old 10-05-2005, 09:58 PM   #14 (permalink)
View abimanyu's Photo Gallery
You can check out thermotec header and exhaust wrap. search google and you should be able to find an online store. Buy enough wrap to wrap your header and the pipings all the way to your muffler. This should gain you another 5-7 hp. Cheap and simple but you might have to get somebody to install it for you.
abimanyu is offline   Reply With Quote
Old 10-05-2005, 10:25 PM   #15 (permalink)
I love Turbos
One problem with header wraps, the cause rust. the wrap gets wet, the heat causes it to evaporate quickly, and that acellerates the rust process when you park it wet.
