Toyota Corolla not starting ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-05-2005, 08:35 PM   #1 (permalink)
View TRD786's Photo Gallery
USA Toyota Corolla not starting ?
Hello
i have a 1998 Toyota Corolla LE. its the USA version that was made with GM, the problem is, past week the car wouldnt start on the first turn, it would just simply "click" now today me and my dad were about to go somewhere, we got in the car and tried starting it, it just kept clicking and never started at all, what could be the problem ? starter ?, gasket ?
it has 110,000 miles on it also
any help would be appreciated
thanks
TRD786 is offline   Reply With Quote
Old 10-05-2005, 09:00 PM   #2 (permalink)
View cashcrazy's Photo Gallery
Have your battery charged and tested. Autozone can do this. If the battery is good it may be a bad altenator.
cashcrazy is offline   Reply With Quote
Old 10-05-2005, 09:06 PM   #3 (permalink)
USA re
the battery is like new, and alternator shouldnt be a problem
but ill go to autozone tomorrow and tryo take the corolla, if its not a battery problem, but idk man
this corolla also eats alot of oil, and dealership said that head gasket was leaking or something, but experienced friends told me if that were true, you would see oil everywhere.
thanks
Old 10-05-2005, 09:10 PM   #4 (permalink)
yea you should be able to see oil on the block. . If you have a charger then charge your battery. I have bought cheap Wal-Mart batteries and had a bad cell in just a couple of weeks. Does your car burn or leak oil?
Old 10-05-2005, 09:34 PM   #5 (permalink)
I love Turbos
View Nismo Convert's Photo Gallery
Check your battery connections, sounds like it's weak. If the head gasket is blown the oil could be entering the combustion chamber and burning off. I would change the headgasket, last thing you want is to starve the motor of oil, and coolant. Thats when it gets really expensive.
1986 Mazda Rx7, was base n/a model, now a 290rwhp, pos monster
1991 Corolla LS, 5spd. Sold
1995 Toyota Tacoma, 3" Lift, Bilstein HD's up front 5051's out back, 265 75 15 Toyo OC A/T's.
2009 Toyota Corolla "S" Magnetic Grey, and oh sooooo Stock.`
Nismo Convert is offline   Reply With Quote
Old 10-05-2005, 10:21 PM   #6 (permalink)
i bought my battery at Sears,
there is no oil on the block, and also no weird looking exhaust, pretty much clear LOL
umm i put motor oil in it frequently, or check on it, going soon to get a oil change, has enough coolant, im going outside right now to check out the block, ill take a picture so you guys can tell me what it looks like
thanks
Old 10-05-2005, 10:31 PM   #7 (permalink)
USA
here are some pics
Old 10-05-2005, 10:36 PM   #8 (permalink)
N/A bites
Tercel GTS's Avatar
Read this thread...
Repair your own STARTER
At the bottom of post is a link to buy parts if you decide to self repair.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 10-05-2005, 10:56 PM   #9 (permalink)
View thoughthard's Photo Gallery
Tercel GTS knows what he is talking about
When my 92 Paseo started doing the "click", I replaced my starter. When I looking inside the old one, the contacts were worn down.
thoughthard is offline   Reply With Quote
Old 10-05-2005, 10:56 PM   #10 (permalink)
USA
i appreciate this help
where is the starter located ?
and is it hard to takeout ?
thanks
Old 10-06-2005, 12:18 AM   #11 (permalink)
1 4/\/\ +3|-| |\|00|3
View dlichterman's Photo Gallery
I had my mechanic do this fix, he said that this is just a problem with the contacts and they need to be replaced after that much wear
dlichterman is offline   Reply With Quote
Old 10-17-2005, 10:26 AM   #12 (permalink)
LilHulaDancer52
View LilHUlaDancer52's Photo Gallery
USA Where is my starter located?
I know this is nuts, but I want to change out my starter myself. I've never done it and I don't know where to start, but I think that i can handle it once someone tells me where specifically it is. BTW, lights can go on- inside and out, won't turn over- just clicks... this does mean I need to change it right?
LilHUlaDancer52 is offline   Reply With Quote
Old 10-17-2005, 10:33 AM   #13 (permalink)
http://toyotanation.com/forum/t27312.html
Old 10-17-2005, 07:21 PM   #14 (permalink)
