1998-2002 Corolla owners - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-05-2005, 09:57 PM   #1 (permalink)
View cashcrazy's Photo Gallery
I have read several posts about these models using oil and other problems. I am at 106k with nothing bad to say so far. I want others to post their year,milage, and any problems to see some of the good(and bad) things about them.
cashcrazy is offline   Reply With Quote
Old 10-05-2005, 10:19 PM   #2 (permalink)
View TRD786's Photo Gallery
USA re
1998 Toyota Corolla LE - 110,200 Miles
Manufactured at - Canada
TRD786 is offline   Reply With Quote
Old 10-05-2005, 10:19 PM   #3 (permalink)
115k miles
01loadedLE's Avatar
Gameroom cash: $123100
View 01loadedLE's Photo Gallery
72k miles on mine with no engine problems. the main problem to me that is normal with these cars is the smelly ac mold which toyota chooses to do nothing about. the only solution since they wont better design their ac's is to run the ac for several minutes before getting into the car. killing the mold with spray is useless it just comes right back within a week.
I have some interior rattles every once and awhile which is also normal for these cars. I dont believe I'll get another corolla. I'll either get a camry or accord next time.
01loadedLE is offline   Reply With Quote
Old 10-06-2005, 12:20 AM   #4 (permalink)
1 4/\/\ +3|-| |\|00|3
View dlichterman's Photo Gallery
98 corolla -116,something miles
-starter contacts
-preventatively replaced serpentine belt
-larger 185-65-r14 tires
dlichterman is offline   Reply With Quote
Old 10-06-2005, 11:27 AM   #5 (permalink)
View petec's Photo Gallery
98 Corolla. Bought 1 month ago with 161,000 miles for $2850.
* 32 MPG city
* Using no oil
* Check engine light on with P0420 code (catalytic converter). Car runs great so I don't plan to fix right now.
* Driver power window switch-button (plastic) broke. Dealer want $200+ for part. Took out and fixed with a tie-wrap to hold switch-button in place..
Hope to get at least another 100,000 miles out of it.
petec is offline   Reply With Quote
Old 10-06-2005, 11:44 AM   #6 (permalink)
Druken Postwhore
TRDragoon's Avatar
View TRDragoon's Photo Gallery
ohhhh, lemme put my input
common things that happens :
-water pump leaks
-noise from timing chain cover are usually the chain.
-serpantine belt tesioner makes noise when loose.
-check engine light comes on maybe cause of VSV failure at tank by-pass, faulty pressure sensor and also dirty MAF sensor.
- and oil leak usually starts from timing chain cov er gasket.
these are usually the only thing that goes wrong with corolla, just make sure you change the air filter around 36000 KM or the MAF sensor get dirty and light come on.
The AE92 Master
UniQue_N_RaRe
TRDragoon is offline   Reply With Quote
Old 10-06-2005, 01:44 PM   #7 (permalink)
the MAF sensor being not taken care of could cause poof performand and gas mileage correct? I think the person who had my car before me did not do this often cause my mileage is kinda crappy......although I do have a horrible drive gas-wise
