Oil pan question?
Well today it was slow at work so I was looking at the diagrams of the 4A-GE and 4A-F and notice that the 4A-GE had an oil baffle on top of the oil pan and the 4a-F had a small oil baffle built into its oil pan. (It doesn't look very effective!) I am pretty sure the the bolt pattern for the oil pans are the same and I think the crankshaft should be the same size (Correct me if I am wrong!) and should not interfer with the 4A-GE baffle with the 4A-F crankshaft (The 4A-F crank shouldn't touch the baffle.) , so I ordered one!! It only cost me about $8 and I think the benefits of less resistance on the crank are worth it and if it doesn't fit then I can sell it on or just keep for when I decide to do my 4A-GE build!! My question is if the baffle fits properly (Which I think it should!) should I look into changing over to the 4A-GE oil pan as well to get the extra oil space? I also thought about trying to figure out some way to use the the 4A-GE oil cooler or find a nice aftermarket one. What do you guys think? Any opinions or advice would be great! Thanks!!
Hear no evil...Speak no eveil...If you don't bring that s**t around you...You ain't got nothing to worry about!!
http://WWW.MORECASHFLOWNOW.COM
Extra Cash Is Always Good!! Click the link to see how to get it!!
