hey guys, i know that having bigger rims will have more grip, but will it actually make your car faster? will these corollas still handle good with say....16 or 17s??? or is it better off the stay with 14s or 15s? and will the rim weight make a difference?? i have a choice to pick 14 inch rims that weigh 10 lbs or 15 inch rims that weigh 15 lbs., which one should i go for? thanks in advance
i could b wrong but i beliee the smaller rims you get the better cornering bc your closer 2 the ground and the center of gavity is better i have 13 inch rims on mine but it came like that when i bought it but no you cant go faster if your rims are bigger or smaller
14s and 15's give you better performance, 16s are somewhat ok on performance but are more for looks, 17s are basically for looks as they take longer to rotate specially with a 4cyl motor as you're probably wasting power in trying to make the tire rotate.
i dunno what you drive but your best bet would be not to go over anything bigger than 1 size over stock
"True car enthusiasts are open-minded to everyone's creation"
"Straight Roads are for Fast cars... Curvy Roads are for Fast drivers "
Cornering and grip would be effected if there was a change in the width of the tire, not so much diameter of the rim. however, i would assume that to some degree by lowering the centre of gravity by using a smaller diameter rim you could have effects on handling. Also the overall size of the diameter of your rim and tire will effect top speed and acceleration. The larger the diameter the higher the top speed but at a decrease in acceleration.
mine came with 14's, wider will be more foward/backward grip, narrower will have better sideways grip, and for some reason, better gas mileage?
i will agree with the narrower tires giving u better gas mileage as for the rest of it in no way will narrower tires be better in cornering (manby in mud and snow but not on the road)
the more tire u have on the road the better grip you will have (an example) u dont see top fuel dragsters using bike tires do u ? tire pressure also plays a big role in traction
if you dont know for sure what you are talking about dont post at all, use the search button and figure it out yourself before throwing out these comments
thanks for the replies guys, but i never got a real answer to my one question, "should i go with 14 inch rims that weigh 10 lbs each or 15 inch rims that weigh 15 lbs each?" which one is better for performance? help me choose....
