Well..............yes and no.
Yes because you don't get as good gas mileage as a stick. Yes, 'cuz you aren't going to have as much control over shifting and other little preferences.
No, because you will probably NEVER have to worry about your torque converter or trans. Unlike a stick which could give some serious problems down the road & the first clutch change will more than make you wish you'd had an auto already.
Top that off...............if you have a throwout bearing problem, or take your clutch disc down to the point of eating into the flywheel............be prepared. Things will get expensive really quick!!!
Also.............stick (while offering much control) is definitel less "hands free" than auto and the older I get, the more I like being able to just drive.
Plus, the way newer cars are shifting, they're getting more & more responsive & silky!!!
Test drive an '06 Lexus IS250/350 once they hit your lot. Those 6 speed trannies will make you wish EVERY car had one!!!!!!!!!!!!!!
