tranny oil change pics? visuals wanted - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-08-2005, 12:55 PM   #1 (permalink)
celica2004's Avatar
View celica2004's Photo Gallery
i saw a lots of posts on tranny oil change.. but no one really tried to include some pics..
its hard to figure out the procedure to drain the tranny fluid from torque converter .. removing hose and draining .. i heard this procedure.. dont tell me again..
any one please take some pics and post it .. it will be of great help coz i planned to change tranny oil next weekend..
just pics will do( visuals are great) .. coz we have lots of info here ... There are lot of people who did changed their tranny oil (automatic) why dont some one get under the car with a camera and get some pics and post it..
people will appreciate it..
thanks
WTF?
celica2004 is offline   Reply With Quote
Old 10-08-2005, 05:23 PM   #2 (permalink)
View dandxg's Photo Gallery
I agree that would be very nice, althought I must say if you are truely DIY, then fork over $15 for the Haynes manual, has nice ones in there on the basic drain and refill. I have read on numerous sites how to do a flush by disconnecting trans cooler lines from radiator so I am going to go for it! I will let you know when I finish, probably not for atleast a month as put auto-rx in engine and trans, I must say trans after 20 miles shifts a bit smoother.
dandxg is offline   Reply With Quote
Old 10-08-2005, 06:00 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
draining the converter?
Old 10-10-2005, 03:15 PM   #4 (permalink)
View redgtxdi's Photo Gallery
Ya, the torque converter....ERRR "DIFF" drain bolt is behind the tranny drain bolt. Problem is that the *fill* bolt for the DIFF is above both of them kinda' located between the firewall and directly below the throttle body. (Hint: If you remove all your air intake crap you can look down & see the bolt-head pointing toward the rear of the car, so you could fill it via funnel & tube by using gravity..............****OR****................(he re comes my beef about trans oils).........
........***IF*** you can still find 'em, they used to make tranny oils..........(I think the torque converter can use strictly ATF, or you can use a 50/50 mix of true trans oil (like 75W90) and ATF.........(don't ask me why, I have noooooo idea what the heck it matters to a differential)...........BUT........every trans oil I've looked at lately (or ATF for that matter) are all just in bottles & that's it!
No more neat little built-in pumps nor any little pumps hanging as an end-cap, "hey buy me, too" kinda' thing right next to them. NUTTIN', honey!!! Just the oils. (Sonsab(*&ches)
EDIT: NEVERRRRRRMIIIIIIND!!!!!!!! I got TC & Diff on the brain cross-hatched!!! Torque converter will drain as you drain trans fluid if you use the coolant bypass hose. Otherwise, just drain/refill your trans at every oil change for a few oil changes & you'll be good.
redgtxdi is offline   Reply With Quote
