is this a bad tranny or cv axles?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2005, 01:12 AM   #1 (permalink)
View lifeisviewtiful's Photo Gallery
are these symptoms of a bad automatic tranny or bad cv axles?
1. when i press the gas my car makes it clacking noise and then gets louder when i accelerate. the car goes in every gear and does not stick.
2. when i turn the wheel and press the gas the clacking noise gets worse is hardly accelerates.
3. it just happened today out of the blue, no warning signs or anything
lifeisviewtiful is offline   Reply With Quote
Old 10-09-2005, 01:25 AM   #2 (permalink)
View 94_Rolla_Guy's Photo Gallery
sounds like CV's check the boots also see if theres any play in them; just turn the wheel to lock then check the boot then with the engine off in neutral grab the shaft and see if it will rotate in either direction
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 10-09-2005, 02:25 AM   #3 (permalink)
Pow! Right in the Kisser!
Liter's Avatar
View Liter's Photo Gallery
i had the same thing ya its the CV boots find out which one it ripped and get it changed asap....if you cant jsut put some elephant shit where the rip is and get it in asap
Liter is offline   Reply With Quote
Old 10-09-2005, 09:27 AM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
Actually it would be the CV joints.. not the boots, if the boot ripped the CV joint would take a little while to actually start making noise. It would have to run completely out of grease before it did that, and if you let it go that far then you might as well replace it because its eventually going to break.
Old 10-09-2005, 07:53 PM   #5 (permalink)
View cashcrazy's Photo Gallery
sounds like CV axles. An easy way to tell is to drive the car on some ramps, then crawl under it and shake the CV's around. If they are as bad as it sounds then you should have a ton of play in one or two of them. Also look for a missing boot. If a boot has been gone for a long time then it needs replacing. MY wife ran her car for 25k missing a boot. She told me it was clanking so i crawled under it and the CV was about to fall out. Hope that helps you out.
cashcrazy is offline   Reply With Quote
