1992 Corolla DX with Rough Idling...
Hi, I own a 1992 Toyota Corolla DX Sedan FWD automatic with approximately 105000 miles on it. The problem with my ride is that it's vibrating (shaking) the whole car when it is on either Drive, Reverse, 2nd Gear and Low Gear. Sometimes my car vibrates even on park and neutral. Anyone have any idea what the problem might be? I changed out the spark plugs, distributor + wires, replaced engine mounts(worn out), replaced the air filter(worn), turned the idle screw up (tried various adjustments) and an oil change with the correct specifications as the instruction manual said. Also, the vibrations do sometimes go away whenever I fill up my car with octane booster, fuel injector cleaner, or gas treatment (I don't add them together and then put gas. I add one of them and then fill up with gas) . Once I refill my car with gas without either of those products, my car begins to vibrate outta control. Any advice is more than welcome.
