Originally Posted by phil
you can only upgrade not downgrade.
the older corollas 14" will not fit because they are 4x100 and 2003 and
up corollas are 5x100.
Huh??
the bolt pattern has nothing to do with it, its the size of the rotors and calipers that define it.
I can put 13s on my 89 GTS with no problems and the cars come with 14s as OEM on the GTS and 13s on the SR5 and sedans. After 1990 you can't put 13s on the GTS as they upsized the rotor and calipers, but I believe the SR5 and Sedans retained the smaller rotors right up until 1992.
After 1993 and up you can only fit 14" or bigger and After 2003 you can only fit 15" or higher, but don't quote me on that.
