Advance Ignition Timing for 88 Corolla Gts? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-14-2005, 10:59 PM   #1 (permalink)
View sleepie's Photo Gallery
Hey everyone.. I own a 88 Corolla Gts fwd.. 4age engine.. and I was wondering if I could manually advance the ignition timing or can it only be done by computer? If it involves wrenches n such.. can someone please guide me? I want to advance the timing up to 16 degrees if that's safe for such an old engine.. it has approx. 150k miles on it by the way. Thanks in advance.
sleepie is offline   Reply With Quote
Old 10-15-2005, 12:02 AM   #2 (permalink)
View 94_Rolla_Guy's Photo Gallery
yes you can advance the base timing which will advance total timing. my question is why you want to do this? by advancing it you will lean out the engine cylinder temps will increase and you may develop a knock or ping. if your running on the rich side or lean side sometimes you can tweek it back to stoich a little by adjusting the timing but only in small amounts like + / - 2 deg
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 10-15-2005, 09:58 AM   #3 (permalink)
The reason why I want to advance the timing is to get every little bit of power out of this baby..haha. i did research and found out that 16 degrees is a safe number.. plus its better fuel milage.. so another question.. i can advance the timing just by using a wrench and that timing gun thing? Thanks.
Old 10-15-2005, 01:16 PM   #4 (permalink)
Gameroom cash: $134355
factory setting should be at 11*
Old 10-15-2005, 03:20 PM   #5 (permalink)
Thanks for your replies but no one has answered if the ignition timing can be done manually or if it has to be done by computer. If anyone can help me with that that would really help.
Old 10-15-2005, 05:11 PM   #6 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
It doesnt lean the mixture, it will just ping, because the piston is still going up when the mixture starts burning. You lose power.
And another point is you wont get more power if your ignition timing at wot goes over the factory setting, which is about 30-32 degrees BTDC.
I think rollaguy answered your question. You wont be able to adjust anything except the base timing, which will affect the timing all around, but it really wont give you power, but you may lose some due to too far advanced timing.
Your timing would be about 15degrees BTDC on idle as stock, one degree wont do anything.
Old 10-15-2005, 11:59 PM   #7 (permalink)
^^^ the only thing you will gain is fuel economy with the possibility of pinging (just adding to what you said)
Old 10-16-2005, 03:33 AM   #8 (permalink)
Resident asshole
Flashmn's Avatar
You wont gain fuel economy, because you arent taking out any fuel delivery, you just screw up the timing.
Old 10-16-2005, 05:35 AM   #9 (permalink)
Hmm.. thanks for the replies.. i was curious because my friend did it to his 94 integra ls.. and he could tell there was an improvement.. it pulled more.. he went from 10 degrees to 16.. so yeah.. that's why i was wondering if i could do it with the corolla.. =]
Old 10-16-2005, 06:40 PM   #10 (permalink)
In Ur MOM's Pants
RedruM's Avatar
View RedruM's Photo Gallery
YES YOU CAN Do it... JUST SAY IT TO YOUR SELF THAT YOU DID and there you go.... you now mentally think your car is advanced to 16degress and therefore you will think you're getting better power
besides just because he can do it on a integra doesnt mean you can do the same to the 4age... every motor is different as for the timing... factory setting should be at 10degrees ...i advanced mine to 13 and got 4whp more but it wasnt worth the pinging and slightly rough idle so went back to 11.. which was ideal.
keep the signatures clean please
RedruM is offline   Reply With Quote
Old 10-16-2005, 07:23 PM   #11 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
how is timing connected with rich or lean?
Old 10-17-2005, 04:44 AM   #12 (permalink)
4A-GZE
KnightX_AE86's Avatar
View KnightX_AE86's Photo Gallery
if u wanna set your timing theres 2 ways to do it1 - take off your timing belt and set it wit your pully....2 - move the distubutor around....1 thing i'll never mess wit is a timing on a car unless i got a pro to do it..
KnightX_AE86 is offline   Reply With Quote
Old 10-17-2005, 07:52 AM   #13 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
im outta here
Old 10-17-2005, 09:31 AM   #14 (permalink)
In Ur MOM's Pants
RedruM's Avatar
its connected to rich or lean because timing is exactly what it says TIMING....you're setting the firing times according to the pistons .... if you advance the timing to far ahead then its firing before the fuel and air are compressed fully at the top...
if you retard it too far then you're firing it when the piston is on its way back down and you're loosing the compression on the mixture....
Old 10-17-2005, 09:45 AM   #15 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
i have to know who told you this
