Will the HKS Super AFR work on our cars? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-16-2005, 11:30 PM   #1 (permalink)
View turbo4ag's Photo Gallery
AE86 Will the HKS Super AFR work on our cars?
Will the HKS Super AFR work on our cars?I am talking about the United States Version ECU with the Air Flow Metering device. I am looking for a straight forward answer please, not a "I am not sure" or "I dont think so" or "Get a Megasquirt". I do not have a 4agze nor a Japanese Market ECU nor engine, nor an MAP sensor ECU, nor a 20 valve engine.I dont mean an HKS AFR either, please. The specific product I am asking about, here is a link to its description:http://www.hksusa.com/products/?id=811&rsku=0I have been searching different sites on the net with varied results.Thank You in advance for any answers.
turbo4ag is offline   Reply With Quote
Old 10-16-2005, 11:37 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
I know someone with a V-AFC in a corolla and thats a Vtec controller.
Old 10-17-2005, 04:36 AM   #3 (permalink)
4A-GZE
KnightX_AE86's Avatar
View KnightX_AE86's Photo Gallery
ya v-afc will only work if u have MAP NOT AFM......
KnightX_AE86 is offline   Reply With Quote
Old 10-17-2005, 04:07 PM   #4 (permalink)
I dont want to be impatient, but I asked will the HKS Super AFR work on our cars, not any other devices. And I am asking if it will work on cars with AFM, NOT MAP. Thank You.
Old 10-18-2005, 01:54 AM   #5 (permalink)
Gameroom cash: $134355
directly from their site:
"The first airflow meter correctional device with a built in CPU, the Super AFR corrects the airflow meter map sensor voltage by inputting the characteristics of the airflow meter map sensor into the CPU to calculate the most accurate amount of air flow. --- Since the correction will be made to this specific intake volume, the ratio of fuel will be precise and proportional. The LED screen displays adjustments as they are entered along with RPM and fuel % adjustment (over baseline). The Super AFR is compatible with virtually any fuel-injected 2-12 cylinder vehicle that uses a hot wire, Karmann Vortex airflow meter or pressure sensor."
that should be able to asnwer your question. if it doesn't tell you whether it will work or not, i would advise against it for you.
Old 10-18-2005, 01:51 PM   #6 (permalink)
4A-GZE
wow this guy just signed up on our bored to ask a question and hes already being tryin to act like the boss man.....good job good "toyotaspeed90" for finding that DURECTLY from the site... turbo 4ag next time dont read half of it and run off askin question
