Nobody really makes a CAI for this car. You'd have to do it yourself. Alternately, you could rip the air box out and go with a Ractive (or whatever you like) short-ram intake that'd sit right above the stock piping from the fender, which is sort of a hybrid intake...OBX makes some decent headers for both the 1.6 and the 1.8 Corolla, the only problem is that there may not be a hole for the first 02 sensor. That's easy enough to fix with a good drill bit...
For cat-backs, I haven't found anything. Ebay has some sort of Kyo system from time to time, but I've no personal experience with those.
Headers and intake, assuming you get somebody to put on the headers for you, will probably run you about $300. I'd recommend a front tower strut brace while you're at it, not only are they cheap, they'll also fix the general oversteer (tail swings wide in corners) of that generation.
