here is my advice to you (and what i did with my smallport). Get rid of the smallport wires & cap. Buy a cap for either an ae86 or an ae82 (either has to be a GTS). Choose the cap that has all 5 plug wire fittings facing upwards. Get a bigport cap (any ae92, ae86, ae82 gts rotor will work) and get the wires from a bigport.
the smallport uses the much smaller 5mm diameter wires. this is a very easy upgrade on the smallport all while doing a quick tuneup.
however, if it's never been changed, changing the o2 sensor may have better effects to overall performance and fuel economy (unless you're always at WOT, which the o2 is ignored)
