Hi, help me with "system too lean" problem. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-18-2005, 07:52 PM   #1 (permalink)
View anxious's Photo Gallery
USA Hi, help me with "system too lean" problem.
Hello, everybody,
The check light of my Toyata Corolla 2001 LE was turned on. And "System too lean" was read out through the computer. The O2 sensors were REALLY not working and replaced with new ones. Surprisingly, the check light come back at about 50 miles after the replacement. Could you guys do me favors on this problem?
thanks!
anxious is offline   Reply With Quote
Old 10-18-2005, 08:10 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
too much air and not enough gas, look for a vacuum leak or dirty injectors or more ideas
Old 10-18-2005, 08:16 PM   #3 (permalink)
Thank you, fredk!
Old 10-18-2005, 08:20 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
keep in touch
Old 10-19-2005, 01:53 AM   #5 (permalink)
View 94_Rolla_Guy's Photo Gallery
another few ideas dirty fuel filter, lazy fuel pump causing less than sufficient fuel pressure
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 10-19-2005, 05:02 PM   #6 (permalink)
BigWilly ;)
View rated_w's Photo Gallery
I had an engine too lean code pulled from my ecu a few months back.. it was the MAF sensor..
appearantly, the MAF sensor is a common problem with the 1zzfe as well as the echos.. are you experiencing any hesisitation problems?
rated_w is offline   Reply With Quote
Old 10-20-2005, 09:35 AM   #7 (permalink)
Hi, rated_w,
As you said, every time I had the check light turned off (Unplug the EFI fuse for 30~60 seconds), the car hesitated to start fast or speed up even I step very heavily on the pedal. Do you think that's MAF sensor problem?
thx.
Old 10-23-2005, 12:41 AM   #8 (permalink)
BigWilly ;)
that is precisely what I had happen
I would press the gas.. the rpms would drop for a split second.. hesitate and then go... once I even pressed the gas, and it sputtered for a good 3 seconds when I was making a left turn..
can you get the rpms over 3000 rpm? if you can't it's a good indicator that your maf sensor is gone
IMO it sounds like the MAF sensor to me .. dixie toyota has sold more than 300 maf sensors to corolla owners this year alone.
dealership will charge you 250 Canadian for the sensor (not too sure about american), try to look on ebay or somewhere around there before going to dealer.
If you are looking for the MAF sensor, it's right by the airbox just before the tube that goes into the throttle body..
Old 10-28-2005, 07:32 AM   #9 (permalink)
Hi, rated_w,
I wanna appreciate your great idea. After I had my AMF sensor cleaned, the problem totally disappeared. So, the sensor still works, but it was really dirty. Anyway, the garage guy cleaned it professionally.
Thank you.
My thanks are also due to fredk and 94_Rolla_Guy, your ideas helped me maintain my baby.
good luck to all you guys.
Old 10-28-2005, 08:14 PM   #10 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
You beat me to it! First thing to try is a blast of carb cleaner on the MAF sensor wires. Small fibers from cheap air filters can also coat the sensor wires and cause the same type of lean code and hesitation.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 10-30-2005, 11:46 PM   #11 (permalink)
BigWilly ;)
glad to see it worked out
I was unlucky when I tried to clean mine.. it didn't work.. I cleaned it with electrical parts cleaner.. tried throttle body cleaner too and even carb cleaner...... and it didn't work.. so I had to get a new one ...
enjoy driving your baby.. I know I do
