[quote=tashirosgt;947718]The best thing would be to get a new aftermarket manifold if they are available. Most new ones come with the gasket and bolts for the heat sheild. You will have to get the studs at an auto parts store.
I have a 99 XLS. Last week I got the rear one (Left) welded, & it is still holding. However, after timing belt change the next day, I heard a fine whining noise from the front. Front manifold cracked & was leaking through the heat shield. Got that welded, but did not last more than 5 minutes..
I have yet to see an aftermarket one with heat shield. I would prefer to get one with heat shield. My fear is not having the heat shield could damage wires, sensors, or plugs with the heat. Do you know of any aftermarket one with heat shield?
I do need to replace the flex pipe soon. Last time got the flex pipe welded only 2 1/2 yrs ago. I was hoping to get stainless steel up to the Catalytic. However, so far what I have seen are polished headers without heat shield. Not having the heat shield, especially the rear (Right) one really concerns me.
Going for the Dealer for manifolds alone cost $160 (L) +180(R). Never mind the pipe.
I am not after performance setup. Rather, looking for a quiet and long lasting (relatively) setup. Any advice on new exhaust system for 99 Avalon?
