I'm with them.. both my cars rev to like 2000rpm in the winter in order to warm up the motor quicker.. its called a choke control, in older cars it was manual which meant you had to pull that lever under the dash to keep the RPMs up. In newer cars (88 and up) it became electronically controlled, which meant the computer would raise the RPMs until a certain temperature is reached.
As for shifting, I usually shift about 4000rpm when I'm doing city driving and if I'm getting on the highway or when I'm just trying to get thru slow people, I'll hit about 7300 or almost redline if I need to.
