Originally Posted by 94_Rolla_Guy
I had the third brake light thing, it turned out to be one of the dual filliment bulbs in the tail lights. The filaments had shorted together and when the running lights were on the shorted fillaments would reverse feed 12V into the brake light circuit causing them to be on. To check this with the parking lights on take the dual filliment bulbs out one by one until the 3erd one goes out, then replace bulbs as nessesary also add some di-electric grease to the sockets to prevent corrosion
as for the timing belt every 96,000km or 60,000mi
Rolla_Guy,
Thanks for the advice. It was indeed a problem with one of the brake light bulbs. It wasn't exactly the filament, but it was the brake light socket. It got hot and melted and the two prongs were touching each other, which it did exactly what you were saying but in a different way. Anyway, the problem is solved. It works great
. Thanks for the help. I appreciate it.
Thanks,
BigTattoo
