help my silver top is overheating - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-24-2005, 06:43 PM   #1 (permalink)
View kapone5684's Photo Gallery
USA help my silver top is overheating
ok I have a small problem i needed some advice about I did a swap on my 94 toyota corolla and put in a ae101 20v silvertop engine. It automatic it has only first and second gear and it overheats very quickly. the water pump is good and th radiator is brand new. not sure about the thermostat. Can any body help me trouble shoot these problems?
thanks and I hope someone can help.
Rob
kapone5684 is offline   Reply With Quote
Old 10-24-2005, 10:26 PM   #2 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
AE92
I would suggest checking the thermostat... Make sure all hoses, if not already brand new, are good, or even that there is enough coolant (sounds obvious, but you never know lol)
freakinbox is offline   Reply With Quote
Old 10-25-2005, 01:12 AM   #3 (permalink)
USA thermostat?
so how would you go about checking the thermostat. I was tought at school to hold a light by one end and it should open up if it doesnt move then its bad right?
Rob
Old 10-25-2005, 01:24 AM   #4 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
Well, take it out, and run the car. If it doesn't overheat, bam, it was the thermostat.
You said that the tranny will only shift in first and second?
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 10-25-2005, 04:56 AM   #5 (permalink)
4A-GZE
KnightX_AE86's Avatar
View KnightX_AE86's Photo Gallery
hold a light on one end?? wow that must b some kinda really hot light.... lol
what u do is take out the old thermo and put it in BOIL HOT WATER and u should see it open... if it doesn open then its fine if it doesnt then its time for a new one... dun worry about them costin u 2 much money... they r less then $15 in canada =)
KnightX_AE86 is offline   Reply With Quote
Old 10-26-2005, 01:16 AM   #6 (permalink)
I already figured out the problem I bought one of those trd radiator cap and I blew a hole in the neck of my radiator and I also replaced the thermostat as well and fixed my problem with no heat in the car. thanks for your help.
Rob
Old 10-26-2005, 10:00 AM   #7 (permalink)
4A-GZE
god to hear =D
