Hi!
I'm not sure what kinda headlights / sealed beams the AE86 uses.
However can I assume that they use 6054 rectangular sealed beams?
If so, these are probably the ultimate lighting upgrade that you can do. I don't think they look stupid at all. These are real HID Arc Discharge headlights not some blue coated halogen bulbs.
http://orderxenarc.sylvania.com/orderxenarc/productenlarged.asp?ProductId=141939&CId=%7B50 410FB0%2D102C%2D42B3%2D90C8%2D5F5493934770%7D& NC=1118200219312
If you don't wanna shell out that much money..
Check out these H4 sealed beam replacements
http://lighting.mbz.org/products/
These are E-Code reflectors and the E-Code headlights produce better more usable beam patterns.
you could also get them from this guy
http://www.bergsmamotorwerks.com/store/item.php?item=Hella%20H4%20Square%20Headlights
that is if my assumption was correct.
Anyway regarding bulbs. I used to spend so much money on those blue bulbs, etc etc etc super bright super white... whatever.
I ended up sticking with Philips Vision Plus H4 bulbs (55/60W)
www.powerbulbs.com
Good luck,
1990 Camry DX I-4 Auto Diamond Blue Metallic
