car doesn't start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2005, 07:02 PM   #1 (permalink)
View rice's Photo Gallery
car doesn't start
one of my friend's car doesn't start, it tries to start like 1 time and then after that its a click click click sound, changed battery, changed spark plugs, could this be the starter?? but the click click click sound means the starter is working, right? and...cant be fuel pump because there's oil/fuel/gas on the spark plugs, so what is missing?? and nothing happens if you pump the gas pedal when trying to turn on the key, also the car is draining the battery, BUT took it to auto zone and test it and it seems to be fine, so what can this be?
rice is offline   Reply With Quote
Old 11-01-2005, 07:09 PM   #2 (permalink)
TokyoRacer's Avatar
View TokyoRacer's Photo Gallery
I don't know but your thread title's very missleading..I was like..isn't that what its supposed to do? "car does start"
Kyle's 1990 Corolla SR5 - 2001 Protege ES
TokyoRacer is offline   Reply With Quote
Old 11-01-2005, 07:29 PM   #3 (permalink)
View burnt03's Photo Gallery
Probably the starter. I had a similar problem on my old 4Runner, changed out the contacts and it worked fine after that.
Here's a link on how to do it for a Toyota V6, probably similar to yours.
http://www.off-road.com/toyota/tech/starter/
1990 Corolla SR5 (Mine)
2003 Corolla CE (Wife's)
burnt03 is offline   Reply With Quote
Old 11-01-2005, 09:32 PM   #4 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
Starter...99%...Trying to crank a bad starter will make the lights dim like its draining the battery....Lol...the first thing people do is go out and buy a new battery without checking it out first...I was going to say check your alternator also but if you put in a new charged battery it should have cranked the engine over even if you do have a bad alternator....Good Luck...Radd Guy....
If you must choose between two evils, pick the one you've never tried before.
Raddman is offline   Reply With Quote
Old 11-01-2005, 09:38 PM   #5 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
my car does that sometimes, the click click thing when I turn the key but if I do a couple times it starts, but it's not very often.
freakinbox is offline   Reply With Quote
