When you lower your car, you are increasing your static camber due to the built in camber geometry or kinematics of your suspension. Keep in mind that if you lower your car you will want to readjust your camber or your tires will wear unevenly. Unless you want more negative camber for auto-x purposes.
As far as how much to lower, that is Dependant upon what you want the car to do? In most cases the lower the better (lowering your CG), this will reduce body roll in corners. But if its a daily driver,then you must be concerned with speed bumps, curbs, pot-holes (i.e. ride clearance) so it should still be practical.
anywhere from 1-4 inches is usually acceptable for daily drivers
1995 Geo Prizm LSI
NO Engine - Yet
Soon to be a 4agze, (twin-charged)
