my trunk... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2002, 11:04 AM   #1 (permalink)
Cat
View lazyedwin's Photo Gallery
my trunk...
after that dogs and cats rain lastnight in TO area, i found out that my trunk leaks....
the leak was not very bad but the left side of the trunk is soaked with water
~Toyota Nation~
83 Tercel Hatchback
AE92 RIP
Echo 3DR coming soon
lazyedwin is offline   Reply With Quote
Old 11-11-2002, 12:01 PM   #2 (permalink)
TN Track day addict
View Lafora's Photo Gallery
talk to 1owner. i could guess where your problem is, but he's way better at explaining this stuff than i am
if you came to the "meet" on saturday, you woulda know where the problem is
My blog
Fast and cheap won't be reliable.
Cheap and reliable won't be fast.
And fast and reliable won't be cheap
Lafora is offline   Reply With Quote
Old 11-11-2002, 12:27 PM   #3 (permalink)
Cat
thxs! I'll PM him then!
sorry, I thought it was cancelled....
~Toyota Nation~
83 Tercel Hatchback
AE92 RIP
Old 11-11-2002, 11:32 PM   #4 (permalink)
Corolla Dx's Avatar
View Corolla Dx's Photo Gallery
well if your trunk is leaking the best thing to do is get the rubber ring around your trunk replaced that should stop the leak i know it did with my buddies wrx that had a small trunk leak.
Matt
Corolla Dx is offline   Reply With Quote
Old 11-11-2002, 11:53 PM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
shucks.. I must've missed that part of the meeting! then again.. my car don't leak yet!
Old 11-12-2002, 03:19 AM   #6 (permalink)
Druken Postwhore
TRDragoon's Avatar
View TRDragoon's Photo Gallery
:x grrrrr....mine leaked too.....
and its nothin to cry about :cry: well heck....won't be that hard to fix :P
TRDragoon is offline   Reply With Quote
Old 11-12-2002, 07:17 AM   #7 (permalink)
View Hemi3TC's Photo Gallery
I found on my 82 Rolla Coupe that the gasket for the tail light assembly was old, cracked , and deteriorating. Since I had some silicon sealant(GE Silicone II) I fixed up the old gasket. But it still leaked a little , so I filled in the gap between the tail light and the body so the rain water runs right down from the hatch gutter over the filled in gap bypassing dropping down to the tailight assembly gasket. No more major water problems and water filled spare tire hole.
Since the crimpped metal that the rubber ring mounts to was rusting a little.
I figure water must be wicking through there somehow. There were a few drips and rust trails on the rear body panel. So I also rust proofed, painted and sealed the seam.
So far it seems no more water has been getting in.
Hemi3TC is offline   Reply With Quote
Old 11-12-2002, 03:13 PM   #8 (permalink)
The terrorist
View Xenon's Photo Gallery
lazyedwin I have the exact same problem, and guess what it's my driver side too. My car was parked outside that night and my whole trucnk was soaked with water. But this is not the first time that happens to me, it's your driver-side taillight. You need to go and buy silicone form Home Depot or Lansing and go around the plastic housing a few times with it. If you're able to take your rear light off, than it's even better.. There's two metal sheets over the rear light, and my guess is Toyota didn't do a great job welding them together. So they leak.
There's also a few other parts were it could leak from! The light gasket, trunk gasket. I didn't know why it was leaking. But I washed the car and made sure enough water ran down the trunk, and then I opened the trunk and found out that there's a lot of water around my left tailight housing.
Tell me how it goes! My plan is just to get a new pair of taillights since mine are bother filled with moisture.
By the way, fix this problem soon, or your whole trunk will rott on you.
My sexy AE92 http://members.cardomain.com/ababan
Xenon is offline   Reply With Quote
Old 11-13-2002, 02:55 AM   #9 (permalink)
Druken Postwhore
TRDragoon's Avatar
the moisture in the taillight could be evapourated if you get a hairdryer and warm it up....
but thnx for the tip xenon
Old 11-13-2002, 12:36 PM   #10 (permalink)
The terrorist
Well, you should first solve the leak problem and then dry the water in the tail light...
Old 11-13-2002, 10:06 PM   #11 (permalink)
KDM is in
REN69's Avatar
ahh.. the driver side tailight part.. I remember that part of the meeting now!
http://www.toyotanation.com/forum/forumdisplay.php?f=69
