Check your 02 sensor
Change your Air Filter
If its a manual tranny, use higher gears to keep the engine speed down
don't accelerate fast
I have changed the transmission oil,
I take it this means you have an automatic transaxle. You will inherently have lower fuel economy than corolla's with manual transaxles.
when parked at a stop light or drive through or etc.... put your transmission in neutral don't leave it in drive.
I just put in a bottle STP fuel system cleaning which gave me quite a bit more power
No fuel additive will give you more power, infact you might harm your fuel system. Any power gains from off-the-shelf fuel additives are psychological.
25MPG does seem low, but I've never owned an automatic corolla. I would think 30 - 32mpg highway would be acceptable. My 95' Prizm used to get 36 highway.
Other causes:
Loss of cylinder compression
bad PCV valve
Clogged Fuel Filter/bad fuel pump
