how to diagnose without a check engine light??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-08-2005, 12:52 AM   #1 (permalink)
View chadix24_7's Photo Gallery
Question how to diagnose without a check engine light???
good day!!! =)
i want to check if there are any codes coming out of my ecu, but my gauge panel has no check engine light. i can buy one but it is too expensive.
how to i check for codes? i know the diagnostic box and short e1 and te1... but how do i see them codes?
engine is a hybrid 7age bigport map type.
many thanks! =)
chadix24_7 is offline   Reply With Quote
Old 11-09-2005, 02:27 AM   #2 (permalink)
The TN Member
View punter's Photo Gallery
Is it manual or auto (ECU's plugs are different) what computer are you running?
punter is offline   Reply With Quote
Old 11-09-2005, 06:51 PM   #3 (permalink)
it's manual. i'm using the stock bigport (jdm) ecu MAP type.
Old 11-13-2005, 01:57 AM   #4 (permalink)
The TN Member
Have a look on www.Club4ag.com under tech referance they have ECU pin-outs for all computers.Just wire up a light to the correct pin then follow the normal procedure, an LED would be best since they are low current and won't bolw any fuses if done wrong.
Hope that helps and that its the right ECU pin-out.
Cheers Rob
