gas mileage not good - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-10-2005, 12:56 PM   #1 (permalink)
View rice's Photo Gallery
when i first bought my car, it had about 150,000 miles on it already, but it still gave me about 30 miles per gallon, i've kept an eye on it from time to time and it still gives about 30 mpg, but now the car is about 157,000 miles and after installing a new shifter, my mpg on my 1994 corolla 7afe has gone down by at least 30 miles or so, in other words, usually i can put about 300 miles per tank full, and now only about 270
what is the problem here? i dont think the new shifter did any harm to the mpg, did it? other than that, the car is bone stock, one of the reasons i bought the corolla was because of it's good mpg, i drive the car pretty average
also, this is bothering me, back when my car had 300 to a tank, when my gas meter is down to half, my mile(not the total miles, the one below that when you reset it) meter shows 200, so shouldn't i get about 400 mpg to a tank instead of just 300?? but at the end, i ended up with 300, know what i mean?
i know that adding bolt ons such as headers, exhaust, intake, etc, will decrease mpg, right? but my car's engine is stock....there is no extra weight or anything in my car, and the car seems to be running great! not sure what the problem here is, its almost winter, so i dont turn on the AC, any advice would be great! thanks in advance...
rice is offline   Reply With Quote
Old 11-10-2005, 01:51 PM   #2 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
is it a short shifter? it may not be the shifter itself but maybe you are driving the car harder because of it, and you may not notice that you are. Or maybe your air or fuel filter has bit the dust. Air filters can affect gas milage dramatically! Or maybe you have a leak? just a small one maybe barely noticable. Could also be because the engine is getting older and more worn...
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 11-10-2005, 10:22 PM   #3 (permalink)
Peter's Avatar
View Peter's Photo Gallery
well the shifter should have nothing to do with it....do u use a/c or the heater that kills ur MPG, and also how u drive the car....second maybe a unclean air filted, spark plugs, ? maybe ur cat is stuffed......any of those is a good place to start
Peter is offline   Reply With Quote
Old 11-11-2005, 03:05 AM   #4 (permalink)
View dpiersma's Photo Gallery
Heater hurting gas mileage? I disagree...the cold air outside may cause your mileage to go down a bit but using the heater in and of itself should not cause a mileage drop. You are just allowing the water in the block to circulate thru the heater core when using the heater. In ther US, fuel mixture changes from summer blend to winter also may have a negative effect on mileage or so I was told.
dpiersma is offline   Reply With Quote
Old 11-11-2005, 06:35 AM   #5 (permalink)
View RadRacer3's Photo Gallery
check your tire pressure, if your tires are low you will burn lots of fuel overcomming the xtra resistance.
when my 95' prizm was newer, in the summer I could get up to 380 a tank with about a half gallon or so left in the tank. Have you ever tried running your tank dry, if your car is mechanically sound then you will get close to 400 miles a tank
1995 Geo Prizm LSI
NO Engine - Yet
Soon to be a 4agze, (twin-charged)
RadRacer3 is offline   Reply With Quote
Old 11-11-2005, 06:45 AM   #6 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
I dont get why people bother with 5mpg difference, heck when your corolla does about 15mpg then I'd be worried
Old 11-11-2005, 10:20 AM   #7 (permalink)
View Stan_06Corolla's Photo Gallery
Because when you drive as much as I do, 5mpg is noticable. My 06 corolla more than pays for itself in fuel savings, just because I try to drive it more than my pickup truck.
Stan_06Corolla is offline   Reply With Quote
Old 11-11-2005, 11:01 AM   #8 (permalink)
Resident asshole
Flashmn's Avatar
How do you know I dont drive more than you?
I commute everyday, because I live in the sticks. I dont bother counting mileage, because guess what, its not gonna do you any good, except cause extra stress.
Old 11-11-2005, 12:32 PM   #9 (permalink)
Peter's Avatar
depands, i know in the truck (01 sierra) when i put the the air flow on the windows and turn the heat on the a/c system turns on.....causeing less fuel....it only dose it when i put it oon the windows.....iam not use why this is , but i go 4 mpg less when i used it...
Old 11-12-2005, 07:24 PM   #10 (permalink)
View jjsagain's Photo Gallery
The only time a heating situation would put extra load on the engine is when you have it in the defrost mode which causes the air contioner to dry the heated air in order to quickly defrost the windows. Normal heat settings will not cause the air conditioner to turn.
jjsagain is offline   Reply With Quote
Old 11-12-2005, 07:46 PM   #11 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
rice.. time for a tune up!
Old 11-12-2005, 09:00 PM   #12 (permalink)
Vroom?
freakinbox's Avatar
myth busters did a think on a/c vs open windows for mpg and the suv with the windows open went a shit load longer than the one with a/c.
And yea I drive alot too. I count millage but I don't care how many times I have to fill up. When you floor it off every light and stop sign, floor it most of the time. You stop caring for fuel lol. Worrying just ruins the fun of driving :p
Old 11-12-2005, 09:40 PM   #13 (permalink)
hey REN, define tune up?? like plugs, wires? or......something else?
