C56 final drive - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2005, 03:06 AM   #1 (permalink)
View 94_Rolla_Guy's Photo Gallery
C56 final drive
currently have a C56 in my car took a gamble and ended up with the 4.312 final. My engine is just spinning to fast on the highway 3000 @100km.
transmission seems to be working well, is it possible to put a 3.72 final in it from a C52 and if so do i need special tools to do so
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 11-12-2005, 11:28 AM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
That's not bad actually.. my C52 does 4000 at 120km/h
You'd probably be able to put the final gear on, I'd look at the other transmission and see how difficult it is to take it out.
Old 11-14-2005, 07:31 PM   #3 (permalink)
RedAE102's Avatar
View RedAE102's Photo Gallery
All C-series final drives will swap if you swap the entire bellhousing/axle assembly.
C52 and C56 have the same 1st, 2nd, and 5th gears, it's 3rd and 4th that are a bit shorter... BTW, in an AE102 with 185/65R14 tyres, C52 with 3.722 differential, the engine will be spinning 2890 rpm at an ACTUAL 60 mph (my speedometer indicates ~67 mph at an actual (radar verified) 60 mph. I have the gearing breakdown of nearly every C-series transmission, C40/140, C50/150-C59, C60/160-C66 (C161 and 162 excluded), so if anyone needs it, just tell me what you need and I'll be happy to oblige.
'93 Corolla AE102 XLi saloon
We're all looking for something.... Something to be...
RedAE102 is offline   Reply With Quote
Old 11-15-2005, 01:40 AM   #4 (permalink)
KDM is in
REN69's Avatar
How about posting them.. I found a website that has Toyota transmissions and their gearing but it doesn't have all the series on it.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 11-15-2005, 09:25 PM   #5 (permalink)
RedAE102's Avatar
Here goes... keep in mind that a C## transmission will have the same gear ratios as a C1## transmission... wherever possible, I tell whether a C## and/or C1## was available for that particular ratio set, but that doesn't mean that one can't exist... All C-series transmissions have a 3.250 reverse gear ratio, new generation C55# notwithstanding; they use a 3.214 reverse and 3.944 axle ratio exclusively.
C40/C140
3.545 1.904 1.310 0.969
C50/C150/C50F
3.545 1.904 1.310 0.969 0.815
C51/C151
3.545 1.904 1.233 0.885 0.725
C52
3.166 1.904 1.310 0.969 0.815
C53/C153/C53A
3.545 1.904 1.310 0.969 0.725
C54/C154
3.545 1.904 1.392 1.031 0.864
C155
3.166 1.904 1.310 0.969 0.725
C56/C56M
3.166 1.904 1.392 1.031 0.815
C57
3.166 1.904 1.233 0.969 0.725
C58
3.545 1.904 1.233 0.969 0.725
C59
3.166 1.904 1.310 0.885 0.725
C60/C160
3.166 2.050 1.481 1.166 0.916 0.725
C161 and 162: any help here?
C63
3.166 1.904 1.310 1.031 0.864 0.725
C64
3.166 2.050 1.481 1.166 0.916 0.815
C65/C65M
3.166 1.904 1.392 1.031 0.815 0.725
C66/C66M
3.166 1.904 1.310 0.969 0.815 0.725
C250
3.545 1.904 1.310 1.031 0.815
C251
3.545 1.904 1.392 1.031 0.815
C550/C550A/C550K
3.545 1.913 1.310 0.973 0.804
C551/C551A/C551K
3.545 1.913 1.310 1.027 0.850
Among the available axle ratios of the C-series:
3.526 3.722 3.941 4.058 4.312 4.529
"A" denotes a transmission with fully automated clutch and gearchange, which Toyota calls "Multi-Mode," MMT, or T-Shift5. "M" denotes a sequential manual model (SMT), similar to MMT but without a full automatic mode (all gear changes must be initiated by the driver). "K" denotes a transmission with automatic clutch, but manual gearchange. This is known as "Freetronic".
Old 11-16-2005, 02:00 AM   #6 (permalink)
KDM is in
REN69's Avatar
Nice, thanks for the info.. I'll post the site I got when I get home.
Old 11-16-2005, 01:46 PM   #7 (permalink)
RedAE102's Avatar
There's more....
C250
C251
C550/C550A
C551/C551A
C55# both use a 3.214 reverse ratio and 3.944 axle ratio exclusively
