FMIC... Work in Progress - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-13-2005, 11:16 AM   #1 (permalink)
Wild on the Flip Side
VooDoo's Avatar
View VooDoo's Photo Gallery
finally we got to start working on the FMIC... just thought i'd share some pix
the intercooler... dunno where it came from but the inlet and outlet are flanged. it also comes with an air temp sensor (i think...)
top part of the piping.. thinking of doing some revisions...
had to make a bigger hole on the passenger side, behind the headlight, for the pipe to run through...
the intercooler tied to the bumper braket so we can measure how much pipe we need...
all in all, the pipings pretty much done. left them at the shop for polishing. we'll do the install next week.
Grupo Toyota
VooDoo is offline   Reply With Quote
Old 11-13-2005, 06:26 PM   #2 (permalink)
View micro214_kp61's Photo Gallery
so is it a preparation for.... more boost? TC boost?
1982 Toyota Starlet (SP61) boosted since 2007
micro214_kp61 is offline   Reply With Quote
Old 11-13-2005, 08:15 PM   #3 (permalink)
VooDoo's Avatar
hehehehehe... cooking something up. we got it down theoretically... now all i need is some moolah and the guts to go for it.
Grupo Toyota
Old 11-13-2005, 11:12 PM   #4 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
the IC is kinda small.
Old 11-13-2005, 11:48 PM   #5 (permalink)
The Other White Meat
terrastrife's Avatar
corolla forum, supercharger, old engine. if its not a 4agze its not right :P
yes it looks smal, but that does look quite thick.
lets hope you dont run into idle problems. many a gze with fmic's have lots of idle problems because of the longer pipe run.
terrastrife is offline   Reply With Quote
Old 11-14-2005, 01:08 AM   #6 (permalink)
VooDoo's Avatar
stock boost and compared to the stock ic, its bigger. also, if i remember correctly the S14 runs a same sized ic with a T28 or T3...
Grupo Toyota
Old 11-14-2005, 01:08 AM   #7 (permalink)
VooDoo's Avatar
this is what i'm worried about. but hey... its worth a shot
Grupo Toyota
Old 11-14-2005, 04:19 PM   #8 (permalink)
it's not the size that counts...it's how you use it! lolz
Old 11-15-2005, 03:40 AM   #9 (permalink)
VooDoo's Avatar
hahahahahaha!
Grupo Toyota
Old 11-17-2005, 03:36 PM   #10 (permalink)
Gameroom cash: $134355
i believe the problem mainly derives on AFM based engines..... i think it has to do with the fact that the s/c is in vacuum at idle and the afm might not open up much since it will be harder to get air through the system.....
Old 11-17-2005, 04:55 PM   #11 (permalink)
Resident asshole
Flashmn's Avatar
Shouldnt be the issue, because air is a constant amount in the tubing.
I was led to believe 4A-GZE's were map sensored.
Old 11-17-2005, 05:05 PM   #12 (permalink)
only late late ae92 and ae101 motors were map.... all US sc mr2's and bigport gze's are afm
Old 11-17-2005, 05:14 PM   #13 (permalink)
Resident asshole
Flashmn's Avatar
Oh I see.. hmmh, well still the afm shouldnt be a problem, unless you have an intake leak or put some sort of blowoff/relief valve that vents to the atmo. Aslong as its airtight after the AFM, no problemos
Old 11-17-2005, 05:17 PM   #14 (permalink)
there is one (the ABV.... 'air bypass valve') but it's post-supercharger
again, the problem is only an idle problem.... most say that with an FMIC and a gze the car usually runs better/faster when on the throttle
Old 11-17-2005, 05:33 PM   #15 (permalink)
View leasaunce's Photo Gallery
nice work!!
Custom CAI ll Borla Cat-Back Exhaust ll DIY Needle Colour ll
ll TRD Bodykit ll Sports Springs ll Chrome Grill ll GEN 4.5 HEADLIGHTS w/PROJECTORS ll
leasaunce is offline   Reply With Quote
