part that tire mounts on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-14-2005, 10:56 PM   #1 (permalink)
View asus's Photo Gallery
I was using an impact wrench today, undoing a lug from the tire, the rusted lug broke the bold lug assembally off.. so insted of 4 holding the tire on, only 3 are now. What is this plate called with that 4 vertical threded things that allow me to atach my tire to the car? thanks
asus is offline   Reply With Quote
Old 11-14-2005, 11:54 PM   #2 (permalink)
I love Turbos
View Nismo Convert's Photo Gallery
You mean the hub, and the studs?
1986 Mazda Rx7, was base n/a model, now a 290rwhp, pos monster
1991 Corolla LS, 5spd. Sold
1995 Toyota Tacoma, 3" Lift, Bilstein HD's up front 5051's out back, 265 75 15 Toyo OC A/T's.
2009 Toyota Corolla "S" Magnetic Grey, and oh sooooo Stock.`
Nismo Convert is offline   Reply With Quote
Old 11-14-2005, 11:58 PM   #3 (permalink)
Moving Forward
View Cyorke's Photo Gallery
teh studs are waht you screw the lug nuts onto. the hub is waht the studs are mounted in. If you are wanting to replace the one that is broke you do not have to replace hte entire hub.
Use a pretty good size hammer and knock the old stud out then you will put the new stud in and use a lug nut to pull it into the hub. it will take a little bit of time to do it if you want to do it yourself. or you can take it womewhere and ahve them jsut replace the stud taht is broken
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
