Odd noise on accelleration- 2001 Corolla S - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-15-2005, 02:27 AM   #1 (permalink)
View 200CorollaS2001's Photo Gallery
For the longest, anytime I went thru heavy rain and hit some large puddles, my 2001 Corolla S would make this weird almost gurgle noise that sounded like water or something got into the exhaust or engine, but very quickly went away.
About 2-3 months ago, I started hearing the same noise when accellerating hard on tight turns. Now I am hearing this sound when accellerating hard at most times.
I have yet to find somebody I can trust with my vehicle, as the local dealership seems to have real boobs working there, and other places don't even know the car's layout as well as I do.
I read in other forums of same sound in rain, and turned out to be a leak in exhaust seal. But nothing about it in dry weather.
I was hoping somebody has some good guesses on this one. One of my first thoughts was low transmission fluid causing some air to get in causing that noise, but my fluid is fine and still looks new. But the noise has a fluid type noise or pattern to it. I am thinking some fluid is getting air mixed in with higher Gs and then settles. I am pretty sure it's not the engine, becuase I can put it in neurtal and rev it when it's doing it, and it stops untill I accellerate in gear again.
BTW, still have that error P0420 code, but I'm replacing the converter and sensors soon to fix that one. Wonder if there is a connection by some chance? I do have a belt tensioner issue ( other thread), but that doesn't sound like the same noise to me.
If only I had a reliable dealer to goto locally
200CorollaS2001 is offline   Reply With Quote
Old 04-16-2006, 01:24 PM   #2 (permalink)
View DoubleEdgedWomb's Photo Gallery
Air in the heater core?
DoubleEdgedWomb is offline   Reply With Quote
Old 04-16-2006, 10:35 PM   #3 (permalink)
Default
View twopointfivebar's Photo Gallery
I had the same problem with my '99 Corolla... sounds hurting when it rains and during accelleration. Everything is the same except you got the VVTi.
I replaced the front exhaust gasket that connects to the manifold. It was completely gone... melted to almost nothing... all I had left was just a few pieces of the wire mesh.
It's kinda easy to replace, you just need to jack up the car high enough so you have room to play.
Here's the link to the part in case you need to know specifics:
http://replacement.car-stuff.com/par...howdc=true#top
twopointfivebar is offline   Reply With Quote
Old 05-29-2006, 11:26 PM   #4 (permalink)
View articledon's Photo Gallery
I hear a similar sound on my camry. But for me it is not only when it rains. It always happens. especially when I first start up.
2003 LE 20% tint all around
Future plans: 18" rims, foglights,new stereo system
articledon is offline   Reply With Quote
Old 05-30-2006, 08:07 PM   #5 (permalink)
View Ghost's Photo Gallery
There was almost an identical problem on this forum I think a couple months ago. The person i believe had a problem with an exhaust gasket?
Search the forum....Possibly its still here somewhere
Ghost is offline   Reply With Quote
Old 06-11-2006, 12:01 AM   #6 (permalink)
celica2004's Avatar
View celica2004's Photo Gallery
Dude check the donut gasket.. I had the same problem.. donut gasket was broken and it left a gap between manifold and exhaust pipe.. check for any bends too..
SImple test.. when you put you hand near donut gasket region and exhaust gases will hit your hand. Also check on the radiator if you find any black residue marks (due to gases) that also indicates broken donut gasket (donut costs about $5)..
WTF?
celica2004 is offline   Reply With Quote
Old 09-04-2006, 11:17 PM   #7 (permalink)
View 2001CorollaS's Photo Gallery
Whoops, I feel bad I never updated this. Yes, it was an exhaust leak. Easy fix.
Side notes, great advice here on cleaning throttle body, MAF and SEAFOAM treatment. Hopefully that fixes my hesitation, certainly imporved the performance.
2001CorollaS is offline   Reply With Quote
