drive without air filter = more powers?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-19-2002, 07:26 PM   #1 (permalink)
View Kaz Tuning's Photo Gallery
when i went home today, i opened the hood and
i saw the filter was unscrewed, and i find it right beside
the transmission, :o
will the dirt make damges inside the engine ?
but i can feel more powers without a filter,
i was about 3-4 cars distance in front of a RX300
in 2nd gear about 6000 rpm
when we both start in a traffic light
i showed that guy the powers of a 1600cc :P
Kaz Tuning is offline   Reply With Quote
Old 11-19-2002, 07:37 PM   #2 (permalink)
operation boro thunder
View project trueno's Photo Gallery
because the air intake is less restrictive, of course there is more power
but w/o a filter, dirt can get inside your engine, and it wouldn't be healthy in the long run
but in track some ppl don't even have a filter...
project trueno is offline   Reply With Quote
Old 11-19-2002, 07:54 PM   #3 (permalink)
View Rolla GT-S's Photo Gallery
don't do it, air filters are there for a reason! even a small amount of dirt can ruin an engine, builds up slugde. If you want more power take out the air silencer and use a hose and run it to the front bottom end where cold ram air will enter, which I did. Yeah, show 'em your 1600cc can kick!
Forever 4A-GE
Rolla GT-S is offline   Reply With Quote
Old 11-20-2002, 08:03 AM   #4 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Yeah, you'd get alot of crap in your engine = busted damn soon.
Imagine a truck passes by you and sends off a cloud of dust/sand, where do you think that sand would go home made bore honing ;P
Old 11-24-2002, 12:36 AM   #5 (permalink)
View whosnext's Photo Gallery
When small particles enters the intake and into the combustion chamber, the dirt particles is enough to bore your sleeves as the piston move. One particle is not going to make a difference and usually get's burned up. But think of thousands of little grit that etches the sleeves and boring the sleeves. This will cause major problems in the long run. Think of dirt as sand paper rubbing alongside the engine block. That means leak and more moeny spent rebuilding engine. Please...leave the filter on or get a air intake system. It'll save you money in the long run
whosnext is offline   Reply With Quote
Old 11-24-2002, 01:54 AM   #6 (permalink)
i didn't do this on purpose ,
the air filter was not tight well , so it drop
Old 11-24-2002, 12:10 PM   #7 (permalink)
so what year is your car, is it a gt-s?
Forever 4A-GE
Old 11-24-2002, 12:26 PM   #8 (permalink)
Resident Wrench Monkey
ek-9's Avatar
View ek-9's Photo Gallery
If you felt a HUGE difference, maybe it's because the filter is rather dirty?
BTW, the Pan hard rod is still here
ek-9 is offline   Reply With Quote
Old 11-24-2002, 04:55 PM   #9 (permalink)
which car are you talking about?
the one had been drive without filter is AW11
and the panda 86 is a gts,
i will try to come as soon as possible,
but what time do you prefer?
Old 11-25-2002, 11:12 PM   #10 (permalink)
don't remember where i read it from, but if you want more power because more air flow, some one hooked up a cpu fan to air intake & put switch inside car, so you can flip it to force more air in, sorta like a mini turbo, ha ha funny isn't it? who would think of such? :P
Forever 4A-GE
Old 12-04-2002, 10:47 PM   #11 (permalink)
gzus13's Avatar
View gzus13's Photo Gallery
Just get a high-flow filter, like a K&N or something.
As for the CPU fan, it may make it easier to pump cool air to the intake, but it will not work as a turbocharger. Just compressing air to 1psi takes 1800 watts - a drain that most stock electrical systems can't handle (at least not without dimming lights, cutting out heater, etc.). It might make some difference, but a cold air intake should be just as good, and you won't have to worry about dimmed headlights.
2 Timothy 1:9-10
Rachel - '88 Corolla DX sedan
Allison - '86 Corolla GT-S coupe
gzus13 is offline   Reply With Quote
Old 12-04-2002, 10:48 PM   #12 (permalink)
gzus13's Avatar
2 Timothy 1:9-10
Old 12-05-2002, 02:47 AM   #13 (permalink)
View livininthefastlane's Photo Gallery
driving w/o air filter...noooooo
yea....dude, not a good idea. you might as well just pour dirt in your engine...its about the same thing... :evil:
livininthefastlane is offline   Reply With Quote
