00' Corolla dashboard bulb - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-19-2005, 05:54 PM   #1 (permalink)
View green_corolla's Photo Gallery
USA 00' Corolla dashboard bulb
Hello All,
I have a 2000 corolla with its first major problem. The central bulb on the dashboard dosent work. I have checked the fuses and they seem alright. I think that there are three bulbs that light up the oil level and tachometer and the central one does not light up.
I have joined this forum in the hope that it would help me fix it.
Thanks!
green_corolla is offline   Reply With Quote
Old 11-19-2005, 11:35 PM   #2 (permalink)
BigWilly ;)
View rated_w's Photo Gallery
vamp.darkravers.net
look at the DIY's and look for something with the dash cluster.. I know the DIY is there..
rated_w is offline   Reply With Quote
Old 11-24-2005, 09:18 AM   #3 (permalink)
View cg2ae88's Photo Gallery
very easy fix. remove the three bolts on the black instrument cover shroud.
next remove the for bolts holding the instrument. unplug the three connectors behind the instrument cluster. note* to release the connectors push down on the tabs and pull on the connector housing. The bulbs should have matching colors. you will know when you have the right one because it will have a green cover over it. to remove the bulb turn cover counter clockwise. if you want to change the color of your dashlights just remove the bulb covers. and you will have a white dash. good luck.
cg2ae88 is offline   Reply With Quote
Old 11-30-2005, 09:49 AM   #4 (permalink)
Thanks cg2ae88 vbmenu_register("postmenu_1009893", true); ,
I will will work on the car this weekend..and let you know how it goes.
Old 11-30-2005, 09:51 AM   #5 (permalink)
Originally Posted by rated_w
vamp.darkravers.net
Thanks rated_w, I found some info in the the DIY....I also tried to locate the blots as mentioned ny cg2ae88...I intend to pull it apart this weekend and will let you guys know how it goes.
really appreciate your help
Old 12-09-2005, 05:27 PM   #6 (permalink)
I tried to get to the dashboard cluster. I found just one bolt...there are not other bolts that i could loosen and I could not get to the cluster. I now have a new problem, my car revs up but take some time to start....i am told that it could be something to do with pressure and fuel injector and replacing that will cost me $400.00....I think I am doomed!
Old 12-10-2005, 02:45 PM   #7 (permalink)
View Inland99's Photo Gallery
Tilt your steering wheel all the way down. You'll find 2 phillips head screws on the top of the black plastic cover that's covering the cluster assembly. Kind of a pain to get the cover out around the steering wheel. Then you'll find 4 phillips screws holding the cluster assembly in place, 2 on top, 2 on the bottom. Then pull cluster straight out. There will be 3 or 4 wire harness plugs you'll have to unplug. All the idiot lights are the small #1895 bulbs. The larger green shaded bulbs are larger ones, 3 or 4 of them. 5 minute job.
Inland99 is offline   Reply With Quote
