I was set on buying EIBACH springs for my 1991 AE92 but then i found that there are APEX springs with more drop also. I have intrax on right now.. but they suck and my car hits the bump stop too much
to decide.. in need to kno... will the apex sag...
will the eibach's sag (so my ride height is good)
Which are stiffer??
how's the wheel well gap with each one?
i have 17in SSR's with nitto 205 40 17's on
(i have neg .5 in wheel well gap in front)
i have apex springs with probably 60-70k between the 2 owners no sag as of yet they seem a little harsh sometimes but i don't have much to compare too. they definately make the car handle nice
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
Eibach's give you a 1" drop only, the APEX and Intrax give you 1.7" but APEX springs are better springs than the Intrax IMO. However the APEX springs will be just as rough as the Intrax they just won't sag though.
If you go to APEX springs, you won't see too big of a difference in ride quality, however struts will make a bigger difference. What do you have for struts? I have KYB GR2s on my 89 GTS and OEM on my 90 GTS, both have APEX springs and I think my 89 GTS rides better than the 90 GTS. I'll be doing either a KYB AGX adjustables up front + GR2 on the back OR Tokico adjustables all around depending on money issues. I'll probably end up going with the KYB setup instead as I have some inevitable purchases to do soon.
You have the same gap I do.. enough for a finger to get in. No I didn't cut the bumpstops, and the shop that did the struts for me didn't suggest it either, not sure if it would make a diff.. it might though. I don't have AIM btw, and performance wise... not sure. The Eibach might be more comfortable than the APEX though as the Eibach is only a 1" drop.
how harsh if ur ride?... does ur car hit the bump stop at every little tiny bump?
Mine goes BOOM at biggere bumps ...... then i shed a tear ='(
If your Apex + KYB setup is good then i'll get it..... if not.... i dunno
HELP PLEASE... u can also email me at azntiger86x@Hotmail.com
btw.. my mechanic said that my bump stops were already cut and he might have also removed them since my intrax dropped my car soooooooo DAMNNNNNN LOWWWWWW
Depends what your meaning of small ones is.. my car seems to bottom out most of the time. BTW do your tires/wheels rub the fenders or the frame??? Reason I'm so curious is that there's a couple of sets of 17" wheels I've seen for sale that I'm interested in buying.
what suspension do you have, I;m interested in this thread because suspension is another area I was thinkin of upgrading, not that the sr5 suspension is all that bad, I just think I want tighter.
