Originally Posted by epyon22
so now thats its getting around 35 degrees ferenheight around here ive noticed that when im crusing around 45-60 mph the engine temperature gauge actually goes down to the cold mark. now i think this is the thermostat stuck open or another sugestion is the coolant is not diluted enough. but i was wondering if any of you guys have had similar problems
Just changed my friends with the same problem, After take out we boiled/cooled the thermostat and it didn't close completely till 110F...Replaced it with a new 195F and it works great now
at least yours doesn't stick closed
...Also remember to "burp your system after replacing the thermostat,....I could also be your temp sender, we had to replace that before too, there's a way to test your sender but I can't remember how
...good luck...Radd Guy...
