Tire PSI for 97 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-26-2005, 12:11 AM   #1 (permalink)
View 97 corolla's Photo Gallery
Tire PSI for 97
does anyone know the tire PSI for the 97 toyota corolla dx sedan
97 corolla is offline   Reply With Quote
Old 11-26-2005, 12:12 AM   #2 (permalink)
View Maxpayne124's Photo Gallery
should be 32psi. look in your users manual/glove box/ driver side door pillar. their usually in one of these 3 places
780tuners.com
corollacustomz.ca
toyotanation.com
Maxpayne124 is offline   Reply With Quote
Old 11-26-2005, 12:42 AM   #3 (permalink)
Peter's Avatar
View Peter's Photo Gallery
also...if there not factor tires i would go by what the tire says it should say some where on the wall of the tire..around th 30+ psi mark
Peter is offline   Reply With Quote
Old 11-26-2005, 12:43 AM   #4 (permalink)
View coroman's Photo Gallery
30psi?
coroman is offline   Reply With Quote
Old 11-26-2005, 08:31 PM   #5 (permalink)
View KaMLuNg's Photo Gallery
32 psi on my 97 rolla DX
'01 GS430
'07 Acura TL
'98 3.2 TL
'07 Rolla LE
KaMLuNg is offline   Reply With Quote
Old 11-27-2005, 08:40 PM   #6 (permalink)
View lawabidn's Photo Gallery
I run 36 front 32 rear, helps tire deflection during hard turns.... helps tire life, better gas mileage
lawabidn is offline   Reply With Quote
Old 11-27-2005, 10:04 PM   #7 (permalink)
touringcamry's Avatar
Gameroom cash: $510725
That's the max pressure you can safely inflate the tires to before it blows off the rim, not the pressure to run normally in the tire. You can generally inflate a bit to seat the bead, but then it needs to be lowered once it's seated.
2007 Camry 2.4L 5M
Old 11-27-2005, 10:05 PM   #8 (permalink)
For most cars, the pressure is around 30PSI. And yes, I mean cars, not trucks, suv, minivan etc. My truck at work has 80 PSI in the tires and HUMVEEs get 20 or 25 PSI IIRC.
2007 Camry 2.4L 5M
Old 11-28-2005, 01:51 PM   #9 (permalink)
View Patman525's Photo Gallery
i do about the same in my '97, but my tires say 35 psi so i do 36 front and 34 in the rear
LoW 'rOllA
Patman525 is offline   Reply With Quote
Old 11-28-2005, 05:09 PM   #10 (permalink)
slow 97 CE
View kevin_alvarez's Photo Gallery
34 front, 32 rear thats what i do in my 97 ce
kevin_alvarez is offline   Reply With Quote
Old 11-28-2005, 05:56 PM   #11 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
Low profile tires neew ALOT more pressure than normal high pro tires. I have 38-40psi in my tires.
Flashmn is online now   Reply With Quote
Old 02-02-2006, 01:37 PM   #12 (permalink)
View chewbaccamonkey's Photo Gallery
well, my tires say 44 MAX, so I ought to be safe with the 36 front 34 rear?
I just like the sound of it. Try it for a few tanks of gas, see if it helps, see how it rides.
Currently running 30psi front and back.
chewbaccamonkey is offline   Reply With Quote
Old 02-02-2006, 08:26 PM   #13 (permalink)
mickeyd's Avatar
View mickeyd's Photo Gallery
Tires wear prematurely if they are over or under inflated. Tire pressure information will be found in the glove box.
mickeyd is offline   Reply With Quote
Old 02-03-2006, 07:06 PM   #14 (permalink)
View rice's Photo Gallery
im surprised no one said this yet, but its 30+ psi COLD!! dont forget, tire psi increases when you drive, so dont check it untill you left it parked for a couple hours, if i remember correctly, when i checked my tire pressure when it was hot, i was around the 40+ psi mark, and around 32+ psi cold
rice is offline   Reply With Quote
Old 02-03-2006, 10:57 PM   #15 (permalink)
Occupation : Foole
View PhantomS's Photo Gallery
Very true - good point
PhantomS is offline   Reply With Quote
