4age keeps bouncing off 3-4 grand ??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-27-2005, 06:18 AM   #1 (permalink)
View kravit's Photo Gallery
Angry 4age keeps bouncing off 3-4 grand ???
Hey guys recently done ae86 4age conversion and keep getting revs bounces from 3-4 grand, it also reving a steady pace and 1 1/2 revs, what hell goin on ??
kravit is offline   Reply With Quote
Old 11-27-2005, 08:53 PM   #2 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
You mean that it won't rev past 4k, is that what you're saying? Normally the cause of that is the wrong ignitor.
-Doc
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 11-27-2005, 08:55 PM   #3 (permalink)
Gameroom cash: $121755
or bad wiring somewhere. ecu might be in a 'limp home mode'.
1) 1990 Corolla "SR5", part silvia, 7age.... & more 2) 1986 MR2, "MK1.22" 91 5SFE/S54 swap 3) 2010 Corolla S 5-speed (the super nice/low mileage DD - wife) 4) 1998 Camry (the boring, high mileage DD - me)
Old 11-27-2005, 09:21 PM   #4 (permalink)
Hey, well it revs to 3k and bounces of it to 2 1/2 revs and keeps bouncing from there if i keep my foot down,wont pass it
Old 11-27-2005, 09:43 PM   #5 (permalink)
Could it be timming ?, i did take of my cams to spray them, but i aligned back up with their dots and bottom pully.
I just did test without throttle sensor and it would just rev to 3 grand and bounce of it like usual,so its not that
Runs alrite, not pumping out bad fumes or poping or runing slugish, kicking ova first kick aswell
Old 11-27-2005, 11:32 PM   #6 (permalink)
4A-GZE
KnightX_AE86's Avatar
View KnightX_AE86's Photo Gallery
i had that prob b4 wit my gts..... change your fuel pump
KnightX_AE86 is offline   Reply With Quote
Old 11-28-2005, 12:29 AM   #7 (permalink)
I got brand new fuel pump, does matter if tank isnt too full ??
what you mean by ingniter, spark plugs or distributor ?
Old 11-28-2005, 01:30 AM   #8 (permalink)
Well I just took my distributor cap off and there is alot white crap in little holes and pretty dirty inside distributor, could be reason ?
Old 11-28-2005, 02:56 AM   #9 (permalink)
I give up, dont know what to do, maybe leave long enough it will fix itself
Dont think mobile mechanic will offer much help, since wont know much about these engines, need 4age pro !!!
Old 11-28-2005, 03:41 AM   #10 (permalink)
The Mad Scientist
Could be, replace it and see what happens.
-Doc
Old 11-28-2005, 04:57 AM   #11 (permalink)
I tried using 4ac coil with 4age igniter unit, thing on top with the plug, doesnt work,car wont even start with old one anymore, geeez just cant win can i
I pretty sure its coil ingnitor, samething happend to this guy http://www.celicatech.com/forums/printthread.php?t=208
Old 11-28-2005, 02:43 PM   #12 (permalink)
you can use an msd blaster 2 coil as well...... the resistances are very close to those of a 4age coil.
are you sure your ignitor is wired in correctly? and that the magnetic pickups for the dizzy are wired in correctly? and are you sure your base timing (which needs to be set with the ecu jumpered) is correct?
also, did you check the timing belt before the motor went in? if it had jumped a tooth on the belt that could be limiting you as well.
Old 11-28-2005, 09:06 PM   #13 (permalink)
Well i just tried another coil @ ignitor, no go, still same problem
Well pretty sure ignitor wire right, just one plug and two leads to positive and negative
What do you mean by ecu base timing ? you mean factory timing ? i have redone the cams and pully and they lined up cams with their dots and lined up pully with Top Dead centre on piston 1 and 2
What do you mean by magnetic pickups on the dizzy ?
anyone think ecu be limiting it ? got stuck somehow ?
Old 11-29-2005, 02:12 AM   #14 (permalink)
it wouldn't get 'stuck'
the ecu doesn't really have a set limiter in it. the rpm limit is based off the time/speed of a crystal in the ecu. you can change your rpm based on crystals that are in the ecu. So the only way it could be 'stuck' is if like i said something else is wrong and the ecu is in some sort of 'limp home mode'
base timing.... you know, with a timing light on the belts pointed at the pointer? lol. Like i said, timing needs to be checked with the ecu jumpered at the diagnostics port. (which means there won't be any sort of advancement or retard adjustments of timing made by the ecu while it's jumpered).
hahahahahahaha, i wonder about this (just came to mind).
what distributor are you running? are you sure it belongs to the ecu/ignitor you have? just because it plugs in doesn't mean it's correct. there are at least 2 or 3 4age distributors. The top cog on the shaft either has 1 tooth or 4 teeth. You need to make sure that you have the correct distributor. If you have an early model ecu (pre 87) then you need to have a dizzy that has one tooth on the top cog. If you have 4 and an old ecu, then that could potentially be the problem.
this is how i thought of this (and an explanation of magneto pickups in a distributor).
the distributor rotates on a shaft, where there's (on a 4age) 2 cogs (or wheels) that are bolted to the shaft. They are directly driven (ie, they don't speed up or slow down based on the speed of the shaft). The electronics in the distributor (again, for a 4age.... the electronics in many other distributors are different as they might contain the coil and ignitor inside) merely 'read' the speed of the shaft. If you play with a distributor outside of an engine, you will feel that there is a little bit of tension on the shaft, and that it doesn't spin freely (ie, you couldn't spin it and let it spin on it's own for quite a while). This is because the electronics actually are small magnetics. As a tooth on the distributor passes by it, the electronic reads it as a pule, and sends out the signals of the 'location' (ie count, because the ignitor/ecu know that there are so many pulses per cog per revolution of the motor).
so.... you could potentially get the engine running with the wrong distributor, but could be getting an incorrect reading from what it expects.
also, if you removed the dizzy and are off one tooth, then potentially timing is off and it won't rev past a certain point because you are getting to a pre-ignition rpm, where spark is happening too late and the engine is doing it on it's own (then gets a spark from the ecu, possibly slowing down the piston speed a bit).
lastly, try just unplugging your TPS for a short run. The ecu gets a reading from the TPS that it is either in a 1-100% open throttle. When it's at 0% throttle then it goes into and idle mode (most manufactures don't have this, actually). If your TPS is wrong (or, somehow one from an mr2 since those read backwards) you could be freaking the ecu out and it doesn't send the right amount of required fuel (and you should be careful if this is the case.... too lean can cause the motor to blow).
Old 11-30-2005, 09:06 PM   #15 (permalink)
Thanks alot toyotaspeed90 vbmenu_register("postmenu_1016071", true); for long detailed help
I took my TPS off again, to my surprised reved passed 3 so its bad TPS, do i realy need one to run it ?
Its weird last time i took my TPS off it would just rev out to 3 grand and would just bounce
