3 speed automatic - whats the interchange?!?! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-27-2005, 12:21 PM   #1 (permalink)
View lawabidn's Photo Gallery
Ok guys, Im hoping someone here can answer a question I 'think' I know... but we shall see
I just purchased a 1991 corolla DX ($100) auto 3 speed with 93k on it. Nice nice car but the trans is trash. suprise suprise someone didnt change the atf in the rear diff area. Trans works but the diff is scredded. I went to the local "pull your own" junkyard and they said the interchange was 1988-1992 1.6 corolla and prizm. Of course I checked every one they had and they were burned up or the diff was toast.
On Ebay they list the JDM 3 speed trans for the 4AFE fit 1987-1995 (?!?!) So I looked at a 1987 Chevy Nova and 1987 Corolla and the trans is still the same looking transmission but the shifter cable hookup and fluid lines are set up different. but they have the same mounting holes in the case, so it looks like you can just swap the cable mounts etc from my trans to make it work. But then again I don't wanna take it out, swap it all just for fun to find it won't work.
So, will a 1987 3 speed auto fit into a 1991 corolla? Please tell me its true!
Thanks in advanced
-corey
lawabidn is offline   Reply With Quote
Old 11-27-2005, 03:57 PM   #2 (permalink)
Ghostridin the whip
Ukrainian102's Avatar
View Ukrainian102's Photo Gallery
4AFE with its 3-spd auto was actually used in base model Corolla's through 1997, so I don't know why it would say -1995.
I have a feeling it should work as long as its meant for that engine (and that chassis especially). Still I may have no idea so don't take my word for it.
http://www.cardomain.com/id/ukrainian102
1995 Corolla DX, 2000 Camry LE, 2004 Highlander V6 AWD
Ukrainian102 is offline   Reply With Quote
Old 11-27-2005, 08:47 PM   #3 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
I'm thinking you could probably make it work as well.
-Doc
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 11-28-2005, 12:52 PM   #4 (permalink)
Yeah, I'll do it and let you guys know how it goes!
Old 11-28-2005, 02:24 PM   #5 (permalink)
omg jdm
aaron7's Avatar
View aaron7's Photo Gallery
lol I never knew the Corolla was available with a 3spd auto! I thought it was just the Prizms.
89 MR2 MK1.5 - endless project. shiny, check. fast... almost installed...
89 MR2 SC - 314k! rims, cams, lsd, pulley, exhaust, intake, header, brakes, stereo, bushings... still going!
74 CB360 - Lots of cool cafe stuff
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, Edelbrock struts, lots of audio
aaron7 is offline   Reply With Quote
Old 12-02-2005, 03:23 PM   #6 (permalink)
View shubey's Photo Gallery
Sorry if its too late but you can use 90-97 3spd autos.From 93-97 swap the speedo drive & neutral safety switch.You can also use the 4 spd autos from 90-92 if you get the mounts with it.It will work as a 4 spd all the time because you dont have a switch to turn it on or off.
shubey is offline   Reply With Quote
