drive belt help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-27-2005, 04:31 PM   #1 (permalink)
View GuJu MaN 89's Photo Gallery
drive belt help
ok i hear a squeling type noise coming from the passenger side of the car, so im assuming its a belt. i have the haynes repair manual for my car which is a 97 Toyota Corolla and it says it doesnt have a auto adjusting tensioner bolt. it also says there are like 3 different belts. do i still need to remove the tire and remove the splash guard to access these belts on the passenger side?
GuJu MaN 89 is offline   Reply With Quote
Old 11-28-2005, 12:23 AM   #2 (permalink)
Nad1370's Avatar
View Nad1370's Photo Gallery
No you don't have to. Just maybe take out the washer bottle out for more room to work around.
Nad1370 is offline   Reply With Quote
Old 11-28-2005, 02:30 AM   #3 (permalink)
View 94_Rolla_Guy's Photo Gallery
if the water pump to steering pump is loose you might need to flex or remove the slash shield to get to the lower pivot bolt..
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 11-28-2005, 02:37 PM   #4 (permalink)
taking out the washer bottle should be covered in the haynes manual correct?
also 94_rolla_guy, do u mean the belt from water pump to steering pump is loose i need to tighten the lower pivot bolt?
Old 11-29-2005, 05:46 PM   #5 (permalink)
any one?
Old 11-29-2005, 06:27 PM   #6 (permalink)
Nad1370's Avatar
^^ you don't have to touch the lower pivot bolt on the p/s. Just loosen the adj. bolt (14mm) up top and yank the belt upwards. Give it a good pull and it will move the p/s pump so you can take the belt out.
Then put the new belt on and get a long pry bar ( 3ft bar/pipe if you don't have one) and pry againts the waterpump to take slack off the belt. Tighten the 14mm bolt while prying.
Old 11-30-2005, 02:23 PM   #7 (permalink)
all belts are on the left side of the engine if looking strait into the engine bay correct?
also, is the P/S belt close to the alternator belt?
Old 11-30-2005, 05:07 PM   #8 (permalink)
Nad1370's Avatar
^ No. P/S belt is the one closests to the firewall. The smallest belt of the 3.
Old 12-01-2005, 02:06 PM   #9 (permalink)
im looking thorgh my haynes manual, and i cant find where the firewall is,
also where can i buy the belts? toyota?
Old 12-01-2005, 02:18 PM   #10 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $113950
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
toyota or any auto parts store.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is online now   Reply With Quote
Old 12-01-2005, 07:02 PM   #11 (permalink)
Nad1370's Avatar
Firewall is what seperates you from the engine compartment.
Old 12-02-2005, 01:34 PM   #12 (permalink)
yea but where is it located in the engine bay?
Old 12-02-2005, 02:16 PM   #13 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Should you be fiddling around inside an engineroom if you cant FIND a FIREWALL.
Old 12-02-2005, 05:04 PM   #14 (permalink)
i think i should lol, i drilled my own firewall when i did my audio system
and the haynes manual doesnt say where the firewall is
Old 12-02-2005, 07:24 PM   #15 (permalink)
View Giantdude's Photo Gallery
well what I did was loosen up the alt. because its almost impossible to get the p/s belt off...All I did was take the wheel off...take the water guard off (underneath the car) and theres a bolt on the p/s pump...lol I really cant explain it..but the bolt was a SOB to get off lol...you'll have to look yourself
Giantdude is offline   Reply With Quote
