Temp Sensor??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-05-2005, 07:40 PM   #1 (permalink)
View Rambo500's Photo Gallery
Temp Sensor???
I replaced my cluster gauge on my 01 CE corolla for one with a tach and the new one also includes an LCD display of the outside ambient temperature. For the first few days of having it installed the temperature was displayed properly, however at one point it would always show ' -30 C ' and now it just says ' -E ' which i am assuming means error. Does anyone know what the problem is and how to fix it? Thanks
Rambo500 is offline   Reply With Quote
Old 12-05-2005, 09:08 PM   #2 (permalink)
View OmarR's Photo Gallery
Are you sure you have the actual temp sensor installed? It should be in front of the radiator. I know you were getting a low reading to begin with, but that could of been an error to begin with also.
OmarR is offline   Reply With Quote
Old 12-06-2005, 02:59 PM   #3 (permalink)
down the middle infront of the radiator there is a wire runing down to about half way were a small plastic thing is mounted. Is this the temp sensor? And if so, why am i getting a -E reading on the dash?
Old 12-17-2005, 06:15 AM   #4 (permalink)
View A-Dad's Photo Gallery
You need to get the temperature sensor and plug it in.... The cars without the temperature guage have the wiring to the front but no sensor. You will find that you will get false readings when the empty plug gets wet in the rain.
A-Dad is offline   Reply With Quote
Old 12-17-2005, 10:52 AM   #5 (permalink)
4A-GZE
KnightX_AE86's Avatar
View KnightX_AE86's Photo Gallery
mayb its just 2 cold.... i remember my rpm tag didnt work when it was freezing cold outside... but after a bit when the car starts to heat up then it'll work again...
just a thought... i might b wrong
KnightX_AE86 is offline   Reply With Quote
