Originally Posted by LILGIRL
I will have to take it in thanks for the help...
I don't think you want to spend the $$$ to take it on for this - it seems to depend on the "shape"/curvature of the nozzle and/or the flow rate of the gas being pumped and/or the "angle" you have the nozzle inserted. I've had this problem randomly, and it seems to happen when gas flow rate is high (likely being splashed off sides of filler tube and tricking the pump into thinking it's backpressure and shutting off), and at certain stations (or perhaps at stations that use a certain brand gas pump....) Dunno the exact reason, but it's likely not a "defect" in your car, just a slight compatability problem with certain pumps (and that can vary - it happens sometimes, and other times not, on the same gas pump locally, but seems to coincide with just how fast the pump is pumping.) And try to ensure that the nozzle is inserted straight and centered ....meaning, park your car with the gas cap as close as possible in line with the gas pump nozzle......We've had our ;05 Corolla since April, and this has happened MAYBE 10 times, if that....
I mean, if you want to take it to the shop, more power to you, but I'd expect you to recieve word that there's nothing wrong with your car.
