88 rolla tries to keep running after shutoff - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-11-2005, 05:47 AM   #1 (permalink)
88 Corolla 4door
View albertmdh's Photo Gallery
My 88 corolla, when you turn the key off and take it out, will continue to turn over a few times, shake rather violently, and try to keep running. What the hell is going on, and how do I fix it.
'87 Supra Turbo 5spd, no mods yet!
albertmdh is offline   Reply With Quote
Old 12-11-2005, 06:17 AM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
I suppose its a carbed corolla... fuel cut solenoid probably.
Old 12-11-2005, 10:29 AM   #3 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
YES mine does that too sometimes lol. Shakes a little and then stops
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 12-11-2005, 11:07 AM   #4 (permalink)
88 Corolla 4door
it is indeed carbed, what do i do about it? how much will it cost me?
Old 12-11-2005, 04:24 PM   #5 (permalink)
20v 4dr AE92
View Corolla101's Photo Gallery
I also had the same problem, what I did to fix it was set the throttle cable to a lower RPM and it stopped doing to for some reason, cant explain what happened but it worked
Corolla101 is offline   Reply With Quote
Old 12-11-2005, 04:31 PM   #6 (permalink)
4Aaron GE's Avatar
View 4Aaron GE's Photo Gallery
http://www.misterfixit.com/diesling.htm
What is happening is that the throttle is remaining partially open when the engine is shut down, which gives the hot engine sufficient fuel to run without a spark from the spark plugs. Most hot engines have sufficient carbon build-up that remains glowing red hot and acts as an igniter for the fuel. The solution is to make sure that the throttle closes completely when you turn off the ignition switch. Check the throttle stop and make sure that the fast idle on the choke or the "bottom stop" isn't what is stopping the throttle from closing.
What? No animation? Bah.
4Aaron GE is offline   Reply With Quote
Old 12-12-2005, 02:45 AM   #7 (permalink)
Pow! Right in the Kisser!
Liter's Avatar
View Liter's Photo Gallery
No idea how to do all that, i have the same problem but what seems to stop it is making sure you kick the choke out everytime you start up the car after it warms up. If it does happen though turn the key back to start and it will automatically turn over. Just kick the choke out again and it will shut off.
Liter is offline   Reply With Quote
