90 Corolla Sedan tire size - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-17-2005, 01:04 PM   #1 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
My dad is having trouble finding tires for his 90 Corolla sedan. The stock tires are 155/r13. What is the equivalent profile for this tire size?
What alternative sizes can fit on the car to maintain the diameter and ride?
Or what 14s can he get cheap to fit and still maintain the overall diameter and ride.
2007 Camry 2.4L 5M
Old 12-17-2005, 02:19 PM   #2 (permalink)
View dandxg's Photo Gallery
Touring you have helped me so I did a bit of homework for you, check out this link from tirerack.com
http://www.tirerack.com/tires/Select...90&autoModClar=
dandxg is offline   Reply With Quote
Old 12-17-2005, 02:34 PM   #3 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
That's not stock tires on those cars.. 165/80-13 or 175/70-13, that's what the car should've came with.
Old 12-17-2005, 10:13 PM   #4 (permalink)
Thanks for the search, but tirerack is the first place I tried. They have zero 155/r13 tires.
REN69: 155/r13 is the stock tire size. Some may have come with 175/70/13 but that may have been for the DX model, the coupes, or in Canada. My dad's car has 155/r13 size tires. There's even a sticker in the glove box that says 155/r13 tires and how many PSI to inflate the tires.
I found that with 175/70/13 tires, I have more options, but I'm not certain whether the tire would fit on the rim properly. The salesman at Sears suggested this also.
2007 Camry 2.4L 5M
Old 12-18-2005, 12:04 AM   #5 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
go to any tire shop and they will tell you size that came on the car or the equivilent to what you have on it. SOme places can also tell you the max size you can put on the car without rubbing. my stock tires are 175/70/13.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 12-18-2005, 12:54 AM   #6 (permalink)
Do white side wall tires usually have one side white and one side black?
Or do they have white on both sides? My dad doesn't want the white side wall tires.
2007 Camry 2.4L 5M
Old 12-18-2005, 06:29 AM   #7 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
I have a base model 90 Prism (identical to your Corolla) and it came with 175/70 13 tires. As for the whitewall issue just have the tires mounted with the whitewalls not showing.
90 GP is offline   Reply With Quote
Old 12-18-2005, 09:11 AM   #8 (permalink)
KDM is in
REN69's Avatar
go with the 165/80-13s then, they're just a tad thicker than the 155/13 tires. If not go to Walmart, they carry Marshals (made by Kumho) that comes in 155/13 size. if your dad wants a more comfortable ride, I would suggest stepping up to the 165s or 175s, they will fit the rim.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 12-18-2005, 10:26 AM   #9 (permalink)
I wouldn't suggest any tire made by Khumo, they are cheap, I will say that, but don't expect more than 20k of wear on them. I have had them, called Khumo corp. in So Cal and they said so sorry no warranty! BTW I had them rotated and aligned on a regular basis.
That being said some people on tirerack like Khumo and have even received a good snow traction rating, there you have it.
I would suggest BF Goorich, from say Sams Club or Costco. I got a set of 4, BF Goodrich Touring TA from Sams for $260 US I think and they have a 70k warranty. They had a tad road noise, because they are a hard tire, but they also will last. Pros and Cons of tire, smooth ride, don't last, harder ride last a long time, usually.
Old 12-18-2005, 11:34 AM   #10 (permalink)
KDM is in
REN69's Avatar
Yeah the marshalls are made as a cheap tire, Khumo are ok IMO, I have a pair of 711s that are holding up just fine with highway driving, I haven't tracked them or beat them so I don't know what kind of limits they would be able to handle, but like I said they do great with regular driving, I've had them to 190km/h though.
