P0401 - EGR location - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-19-2005, 09:17 PM   #1 (permalink)
View smharr4's Photo Gallery
I have a 1997 Toyota Corolla CE with a 1.6L I4 engine that yesterdayseemed to lose power while accelerating and a 'CHECK ENGINE' light cameon, although today the car seems to be fine.
I pulled code P0401, apparently for insufficient EGR flow. I'd like totry and clean the EGR valve and tubes before replacing the part ifpossible
The problem is I don't know where the EGR valve is - I know where it is(and how to clean it) on my 1993 Mercedes, but not on my 1997 Corolla.I don't even know where to begin.
Anyone care to enlighten me where this valve is?
smharr4 is offline   Reply With Quote
Old 12-20-2005, 07:36 PM   #2 (permalink)
View Patman525's Photo Gallery
I put a short ram intake in my 97, and didn't plug back in the mass air flow sensor, not thinking much of it. Check engine light came on, diagnosis said EGR valve misread, so i plugged in the mass air flow, light went out, no codes thrown. see if your mass airflow sensor is in. if it is, i don't know where the EGR valve is, but maybe someone else does. if your MA sensor is out, put it in the air box where the filter is on the engine side. Drive it for a bit so your computer can get recallibrated and then see if its still throwing codes. hope that helps
LoW 'rOllA
Patman525 is offline   Reply With Quote
Old 12-27-2005, 01:49 PM   #3 (permalink)
OneNuke89
View OneNuke89's Photo Gallery
USA
Maybe a little late, considering when the original post was. Anyway, the EGR valve is in the back of the engine, towards the windshield wipers. You'll see what's been described as a "UFO looking" object. That is the EGR Vacuum Modulator. Follow the left (as you're looking at it) vacuum hose and it goes down towards the EGR valve. The EGR valve is actually mounted on the engine, about 6" or so below the EGR Vacuum Modulator. Hope this helps!!
OneNuke89 is offline   Reply With Quote
Old 12-27-2005, 05:29 PM   #4 (permalink)
4A-GZE
KnightX_AE86's Avatar
View KnightX_AE86's Photo Gallery
dunno about ur car but on my rolla its on the headder it self and u cant miss it
KnightX_AE86 is offline   Reply With Quote
