20V head - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-22-2005, 11:48 AM   #1 (permalink)
95 COROLLA's Avatar
View 95 COROLLA's Photo Gallery
20V head
ok this prolly gets asked to many times but i just found a 20v head and im just wondering can you put it on a 4A-FE block? my cars a 3spd auto. and im just wondering can u use the stock exhaust manifold and intake manifold on the 20V head ?
95 COROLLA is offline   Reply With Quote
Old 12-22-2005, 12:17 PM   #2 (permalink)
Wild on the Flip Side
VooDoo's Avatar
View VooDoo's Photo Gallery
manifolds won't fit.
i think major work needs to be done to fit the head. not to mention you'd also need the ecu to work the VVT and the ITB/AFM.
Grupo Toyota
VooDoo is offline   Reply With Quote
Old 12-22-2005, 01:47 PM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
Pistons might have some weird compression ratios if you just plug and play it on.
Old 12-22-2005, 07:59 PM   #4 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
lol yea, I have heard of putting the 20 v head on a 4age but not a 4afe. :p
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 12-22-2005, 09:48 PM   #5 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
The compression ratio would be really low. You would want to also use 4AGE pistons. And you'll need 4AGE manifolds. And if you want to rev to 7800 rpm you'll need to either modify your ecu or use the 4AGE ecu, or a standalone.
-Doc
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 12-23-2005, 03:09 AM   #6 (permalink)
Resident asshole
Flashmn's Avatar
I dont think 4A-GE pistons themselves work, the 20V has cuts in the pistons for the 5 valve design. iirc.
Old 12-23-2005, 07:43 PM   #7 (permalink)
The Mad Scientist
The 20v IS a 4AGE. That's what I meant.
-Doc
Old 12-24-2005, 03:07 AM   #8 (permalink)
Resident asshole
Flashmn's Avatar
oh, I always figure when someone says 4A-GE on forums they refer to the 16V and refer to 20V as 20V
Old 12-24-2005, 05:10 AM   #9 (permalink)
Mr. Nice Guy
canadianae92's Avatar
View canadianae92's Photo Gallery
Well you can just pop on the 16v head if you want.
canadianae92 is offline   Reply With Quote
Old 12-24-2005, 05:57 AM   #10 (permalink)
Resident asshole
Flashmn's Avatar
Yeah, you can, but the 20V head wont work with the 16V pistons that well, afaik.
Old 12-24-2005, 06:53 AM   #11 (permalink)
The TN Member
View punter's Photo Gallery
No a 20v head will go fine on any 4age (Unless your cam belt breaks)
punter is offline   Reply With Quote
