Pls lend me some advice - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-23-2005, 01:14 AM   #1 (permalink)
Aven4231's Avatar
View Aven4231's Photo Gallery
Gen1 Pls lend me some advice
ok hows it goin and thanks for your help, i have a few questions that i would like some aswers to most of the questions are going to be opinion and i thank every one for their info on the matter. Keep in mind this is a 2003 Toyota Corolla Type S
1. How hard is it to swap to a 6 speed/ 5 speed tranny and what year modles of the gts or gtr came with the 1zz with 6 speed/ 5 speed.
2. Ok this will mostly be opinon but what is/would be best for my Corolla. I want a fast but good running car without the heavy work to maintaning it all the time, so should i go supercharger or turbo, And what would be the results of each one.(name brand too pls)
3. What mods can i do to the Corolla without doing anything at all or better yet how can i get the most power out of doing very little.
4. What can i get the most out of my car. ( think in the fact that money is no problem.)
5. What are some good companies to order parts from.
6. Who makes the best stroker kit for my car.
7. Are there any engin swaps that would be worth doing.
8. Pls if any one has any could you send me some pictures of some 2003 type s corollas so i can get a picture for what i want to do.
Oh and thanks again for all who help me i will take every ones opinion and use it wisly thanks again.
Aven4231 is offline   Reply With Quote
Old 12-23-2005, 01:22 AM   #2 (permalink)
Cumberland Reprezent'
View Wiseco's Photo Gallery
First, improve your handling. Get a set of Eibach Springs, get them installed and get the car re-aligned. Then, buy good tires.
Performance wise, first upgrade should be a quality air intake. Steer clear of that made in taiwan crap.
Wiseco is offline   Reply With Quote
Old 12-23-2005, 07:29 AM   #3 (permalink)
Whine connoisseur
View adsaba1969's Photo Gallery
1. Hard? Depends on what you know. It will cost $$$$$$.
2. TRD s/c would be a better bet than a turbo for less maint.
3. Intake, exhaust, pulleys, NO ebay chips
4. Tires, suspension, header, s/c, wheels
5. Do some research on the parts. If you know what you are looking for, you could start on ebay for price, but then use google.
6.
7. Worth doing? No
8. Look in the gallery
adsaba1969 is offline   Reply With Quote
Old 12-24-2005, 08:22 PM   #4 (permalink)
Aven4231's Avatar
thanks for the info i'll be sure to use all of it if there is more pls anyone add your info on the matter.
If seeing is believing for i do not see death, there for I can't die, doth death is blind.
Old 12-24-2005, 09:31 PM   #5 (permalink)
Moderator
Gameroom cash: $492737
View silver04rollas's Photo Gallery
Not to be picky, but Honduhs are 'type this' or 'type that'. It is a Corolla S.
It would be pointless to swap the 6 speed manual with the low-revving 1ZZ FE engine in your Corolla S. The gear ratios on the 6 speed manual are specifically designed around the 8350 rpm high revving characteristics of the Corolla XRS/ Celica GTS and keeping the revs high during gear shifts. If you really want to do a transmission swap, Celica GT 1ZZ FE 5 speed manual have slightly more aggressive gear ratios especially in the 3rd and 4th. It would be much more useful.
Since you have a 2003, which had a mechanical cable throttle system (05 and 06 CE, LE and S are drive by wire throttle system), TRD supercharger is the best way for you to go.
Cold air intake, Catback exhaust, 1ZZ FE DC header, flywheel, pulley etc. All great mods.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/H&R Racing/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
Old 12-24-2005, 09:46 PM   #6 (permalink)
2005 Corolla XRS
357wheelgunner's Avatar
View 357wheelgunner's Photo Gallery
Get the TRD Supercharger, a turbo will be a pain to maintain.
Don't try to swap trannies, the car is too new to invite problems.
Good luck, the 03s are great cars!
Try www. 9th gen corolla .com without the spaces, you will be pleased they are the best for 9th gen corollas bar none.
2005 Corolla XRS
Vibrant exaust, 30% tint, K&N Short Ram Intake, HKS grounding kit, ES motor mount inserts, TRD Springs, Koni Yellow shocks
357wheelgunner is offline   Reply With Quote
Old 12-25-2005, 02:31 PM   #7 (permalink)
Aven4231's Avatar
thanks this informationis really great i thank everyone for helping me on my new car any more information that can be given will greatly help thanks.
Old 12-25-2005, 03:05 PM   #8 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
TRD supercharger would be a plug and play thing pretty much... but mind explaining what you mean by "pain to maintain"?
Old 12-26-2005, 12:51 AM   #9 (permalink)
2005 Corolla XRS
Oil leaks, blown turbo, bad install, complex electronics......The TRD supercharger is easy to install, and is backed by the factory. I'd rather bitch at Toyota about S/C problems than try to complain to armchair commandos when my brand new car blows up due to the turbo the net wizards told me to install. Turbos are more complex than superchargers to install and maintain.
2005 Corolla XRS
Old 12-26-2005, 07:58 AM   #10 (permalink)
Resident asshole
Flashmn's Avatar
True, that can happen, but a supercharger can break too, the teflon lining on them is kinda fragile when it overrevs it breaks. Centrifugal ones are more prone to breakage.
Complex electronics arent necessary, like in my turbo installation, I'm using carbs with the turbo, so its basically mechanical, its even simpler than most EFi setups + supercharger.
Old 12-26-2005, 10:04 AM   #11 (permalink)
2005 Corolla XRS
I truly respect that, but I doubt his 03 has a carburator
2005 Corolla XRS
Old 12-26-2005, 10:16 AM   #12 (permalink)
Resident asshole
Flashmn's Avatar
Yup it definately doesnt, however, a basic EFi system would work just fine, get a rising rate fpr and use that to give additional fuel to the engine when under boost. That is the traditional trick and I'm positive that might be the trick used in the TRD Supercharger too. So no complex devices needed to install. Thats how a friend of mine installed a turbo on a AE100.
Turbocharging isnt as complex as people think, its quite easy, I'd say the hardest part in the installation is making the manifold fit, especially in a 4A-F, there isnt much space between the engine and radiator. Theres the oilfilter there too and oilcooler lines, so I might have to move those to get space for a downpipe, UNLESS I plan to move the turbo above the transmission, which gives some other unpleasant stuff with the downpipe placement.
Old 12-27-2005, 12:38 AM   #13 (permalink)
Aven4231's Avatar
thanks guys just to let you know i am writing all this down so all of it is helping me a lot if you find out ay other information let me know it would be great. thanks
