Ok, I have a 1986 sr5 and I have been looking all over for information on the wiring that I will have to do to drop either the 4agze or the 20v set up into it. I'm sure that there are many people out there in my shoes that have picked up sr5 corollas in hopes of doing this swap and are having similar issues. What I'm looking for in paticular are photographs of the wiring, diagrams with compared differences etc. I need to know if the wiring harness in the sr5 dash will need to be changed to the gts harness, and from there what else I need to hack apart rewire or change over. Here are some of the links that I have come across with good information, but they are not as in depth as I would like them to be. Either way it gos, this project is going to go through, it will be photographed etc. I plan on putting together the wtf you need to do to drop that beast into your corolla walk through.
http://www.users.bigpond.com/vidore/...age_engine.htm
http://www.padandwheels.com/mr2/blac...ng/wiring.html
http://www.toymods.org.au/FWD_To_RWD_4A-GE/
I'll also found a rather large pdf with some very good photos, I'll send it to any one who wants it via aim or msn.
I also need parts! gts rear end, dirve shaft, trans, etc.
Found the pdf link, it says you need to replace the dash harness.
http://www.4age.hu/albums/SR5TOGTS/SR5toGTS.pdf
