Remove the cover where the sunroof switch / map light is. I "think" that you reach up at the front of the cover edge (nearest windshield) and pull downwards to get it off. Unscrew that and you should find the bolt you're looking for.
Only thing is, I'm not sure it cranks shut? When I replaced the cables on mine, it looked as though you loosen off the bolt (under the cover) and it slacks the thing off enough so that you can use your hands to push it shut instead.
What does this tool that you're talking about look like?
1990 Corolla SR5 (Mine)
2003 Corolla CE (Wife's)
