You can email the pics to me for hosting.
drtweak@phoenixtuning.com
In order to do the conversion on the front, you need the hub from the Celica and you need to have a shop with a press replace it. Then you can use the rotor, caliper, and wheel from the Celica. For the rear, you need the hub assembly and backing plate with parking brake parts. Then the bolts for hub assembly and backing plate have to be drilled out a little to make it fit. Once that's done, the hole for the parking brake cable bracket has to be drilled out a little, and usually the cable has to be shortened. Then all the Celica rear disc parts can be used, and of course, you need the wheels too.
Just wanted to clarify that it's not just a bolt-on process, unless you did it differently. I've done this a couple times.
-Doc
