P0304, P0300, and P0103 oh my
Here's a follow up to a post I made last week:
"Having problems with my 98. Recently, the engine has been hesitating from 2000 rpms up to 3000 rpms under moderate acceleration. Above or below that I have no issues at all. If I'm very light on the gas, I don't have the issue either - it just takes 60 seconds to get to freeway speed. Instead, I've been driving like a mad man to keep the rpms out of the "trouble range".
No check engine light. Doesn't seem to be a fuel delivery problem. The engine almost acts like its not getting spark for a second. Makes the car jerk pretty bad. Any ideas for things I can start chasing down?"
Well, I stayed on the gas a little longer today after the engine started bogging down. After about 10 seconds, the engine lite would start flashing. Got it to stay on after about the 3rd or 4th attempt. Here's what I found with my code scanner:
Stored codes:
P0304 - Cylinder 4 misfire
Pending codes:
P0300 - random/multiple cylinder misfire
P0103 - mass or volume air flow circuit high input
P1800 - (unknown code)
I'm thinking the first thing to do is clean my MAF sensor and see if the codes reappear. I checked the plugs and wires and everything looks good. Anything else I'm forgetting to check?
Can anyone tell me what P1800 is for? Couldn't find any info on that one.
Thanks
