GTS brakes and struts into SR5 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-03-2006, 06:15 PM   #1 (permalink)
View OwnerOfReality's Photo Gallery
first things first..... searched for the brakes - closest thing i could find is this http://toyotanation.com/forum/t97702.html
i basically want to know what i need to grab off of a GTS to put in my SR5 for the rear brake conversion
i was also wondering if the rear struts were the same and if the front adjustable ones fit on the SR5?
thanks
OwnerOfReality is offline   Reply With Quote
Old 01-03-2006, 07:14 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
What he said...
to do the rears you will need the entire hub assembly and parking brake cables.
the fronts should be the same as an 88-89 gts...... 90-91 gts had larger rotors. pads are the same, i would expect that calipers are the same as well.....
The rears struts are the same, for the fronts you need the whole strut assembly as if you were replacing the whole strut anyways.
Old 01-03-2006, 08:34 PM   #3 (permalink)
well im hitting up 3 different junkyards friday and im compiling a list to try and grab...
so far for my GTS conversion i have...
Seats
Speedometer Cluster
Oil/Voltage Cluster
Rear Panels w/ Seatbelt Assembly
Center Console (mines broke... is the GTS one different?)
Sideskirts
Front Swaybar (All bracketry, control arms, swaybar endlinks)
Front Serviceable Struts (would it be better to get new aftermarket GTS struts?)
Front Strut Tower Bar
Already Have...
GTS doors (thats why i need seatbelt assembly)
GTS door panels
GTS trunklid w/ spoiler
Clock
also thought about replacing the cruise control on my car because it doesnt work... i just dont know what to look for under the hood
got a new AE92, a few questions... ah_long Archived Corolla threads 58 01-22-2005 12:03 AM
Need struts and springs suggestions... 01 Avalon XLS Dannieboiz 2nd Generation (2000-2004) 7 11-17-2004 01:51 PM
1988 Toyota Corolla SR5 Dave A Archived Corolla threads 20 12-03-2003 01:18 AM
Gen2 Alltrac Camry Brakes and Suspension jonnycowboy 1st & 2nd Generation (1983–1986 & 1987-1991) 1 08-24-2003 08:31 PM
Proud new owner of a 1988 AE92 GTS karma Archived Corolla threads 16 07-30-2002 06:14 PM
